Refrigerators Logo
R
Robert R Pelker Posted on Sep 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Kenmore 25.0 cf, bottom freezer refrigerator is 10 years old. i am finding water collection below the pull out meat drawer. What are possible causes?
Your Consultant
Level 3:
Master:
  • Master 825 Answers
  • Posted on Sep 05, 2019
Your Consultant
Master
Level 3:
Master:
Answers
825
Questions
Helped
206343
Points
1873
High humidity, bad door seal, door not closing completely.
5 Related Answers
Anonymous
  • 98 Answers
  • Posted on Sep 22, 2009
SOURCE: water is collecting in the bottom of the
Drain stoped up. Take off the bottom panel up top drain is in middle at back. remove the ise with hair dryer. air is the best to use to unstop.
victorwod
Victor Nwachukwu
  • 157 Answers
  • Posted on Feb 20, 2010
SOURCE: 10 year old refrigerator with freezer on top.
there is a power failure
Anonymous
  • 4793 Answers
  • Posted on Mar 08, 2010
SOURCE: Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Anonymous
  • Posted on Apr 21, 2010
SOURCE: Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
Anonymous
  • 1891 Answers
  • Posted on Sep 23, 2010
SOURCE: water collects on the bottom of the refrigerator
drain is pluged with ice and may require a drain heater kit . very common problem . mm
1helpful
Have 7 year old Kenmore fridge with bottom freezer and can't pull open the drawer. Should I pull plug?
chances are there is sticky food residue built up to stop it. put a towel in front of the door and pour hot water on bottom shelf
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
1helpful
2helpful
2answers
Water is collecting in the bottom of the refrigerator below the drawers. Water was also in the lunch meat drawer.
Your freezer defrost coils are probably frozen. Or the drain tube is plugged. Remove the rear panel from the freezer and defrost the defrost coils if necessary. Make sure that the drain tube underneath the coils is not plugged with ice or other foreign matter. You may have to thaw out the tube. If you don't make sure that the tube is clear, excess condensate will continue to drain into the fridge. Good luck!
2answers
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
