When turned on, lens extends and retracts repeatedly,then message appears "Turn the camera off and on again". But the same thing happens next time. When message is on viewfinder, I cannot take a photo.
My solution for the M340
I had the same problem after a day at the beach. What I did was get a
can of compressed air (from the computer section) and blow air around
the lens as I repeatedly turned it on. It took about five cycles, but
I eventually cleared whatever was preventing the lens from fully
opening.
Good luck.
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
