I'de suggest you replace the dvd rom.
Well there could be software and hardward problem there. It might be the software is not communicating with the dvd-rom. What you can do is try upgrading the dvd driver.
What is the brand of DVD you are using? If you were ever able to burn dvd's maybe you need to see if the brand you are trying to use now is causing this problem. It could also be the lense gone for reading DVD. Are you able to read CD's.
How long have you been using your dvd? if this is the first time you encounter the problem for a long time..your dvd burner might be damaged..better replace it...hope this helps
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps you
i think last week im still able to burn DVD using windows DVD maker. This problems actually happened twice. I actually can read the CD/DVD. But when i wanted to burn using the Windows DVD maker, the drive not detected.
This is not my first time encouter this problem. i think last week im still able to burn my dvd using windows dvd maker.... but now i dono y cannot see any dvd drive when i try to burn my project using window dvd maker. i can read my dvd/cd but i cant burn..
actually yesterday i tried to uninstall & reinstall my dvd driver... but it still cannot detect any dvd drive. Pls help. Thanks
Im able to read dvd/cd. I think the software only cannot detect the DVD rom drive. I dono why...
