Hayward 1.5hp 230v 2 Speed Uprated Super II Pump Logo
Posted on Aug 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need wiring diagram for Hayward dual Super 2 speed pump. Old unit had 3 wires and new unit has 5 wires.
poolyoda
Level 2:
  • Expert 128 Answers
  • Posted on Aug 30, 2009
poolyoda
Expert
Level 2:
Answers
128
Questions
0
Helped
79733
Points
185
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
  • Roxanne Martin
    Roxanne Martin Apr 29, 2014
    What about wiring connection to a t.stat in the intermatic box?
Where can I find a Wiring diagram for hayward super II PUMP AND BOOSTER PUMP to new t106 intermatic and existing t104 for the booster?
Not sure if you will find such a diagram...
New installation?
Do the pumps have their own breaker?
Is your Super II pump a 2 speed?
What is the Thermostat for? Do you have a heater that you are trying to connect, so that the pump will come on when there is a demand for heat? Not really sure what the T-stat is mentioned for here?
You still only need to have 2 timers if I'm not missing something?
The T-106 will be for the Super II pump (presuming it is a 2 speed version) It will turn hi speed, on & off. or switch between them rather. I think I see why you may be inferring about a 3rd timer? You don't want to have pump running on "Low" speed continually. If so, Then you will need a 3rd timer (T-104) to provide power as Line to the T-106. The other T-104 will be for the booster pump for your cleaner.
The power for the Super II pump from the breaker will go to the 1st T-104 as "Line". Then from the Load portion of that timer, you will wire into the Line portion of the T-106. Following the instructions from the diagram at this website address for a PDF document:
http://www.intermatic.com/~/media/Intermatic/Documentation/Time%20Switches/Mechanical%20Time%20Switches/24%20Hour/T100%20Series/T106R%20Instructions.ashx
you will complete the wiring to the Super II pump via the "Load" side of the T-106
The 2nd T-104 (pool sweep pump) will be wired: from the breaker to the "Line" portion of the timer. From the Load portion of the timer, you wire to the booster pump.
Good Luck
I have a new 2 speed pool pump. I have the wiring diagram that came with your unit, but I'm not an electrician. Is there any way to get a wiring diagram with the wiring colors noted so I can just do the...
Fixya does not sell Intermatic P1353 timer. We answer questions for do-it-yourselfers like yourself.
Open following link for Intermatic P1353 manuals with wiring and programming diagrams.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
1) It is very likely that pump wires will change over color-for-color, but I am electrician and would never do that because I would not want to burn out my new motor without poking around first. I would look at manual for old motor and compare with manual for new motor. I would certainly read the new manual and compare where wires are connected to timer.
2) As a general rule with P1353 timer, High speed connects to terminal 4. Low speed connects to terminal 6. The remaining wire connects to terminal 3 with a jumper wire to terminal 5.
3) This information applies only if you are replacing a 2-speed pump, and timer was wired by diagrams shown in the manual, and timer is correctly programmed for MODE2 2-speed pump.
4) You can add a comment for more free help. I will answer back. I know this timer front and back, it is complicated for novice. And you should remember that I do not know what is inside your pump manual unless you tell me, and I do not read minds.
5) You can also pay for fixya expert to work with you while you work on pump.
1helpful
I am replacing my Hayward 1 HP superpump. The old pump had the 230/115 conversion plug on line 1. The new pump has it on line 2. Do I jusst connect the 115 v(hot) wire to line 2? That would be oppisite of...
It will not matter where you put the hot and neautral as long as one goes on line 1 and the other on line 2. Just be sure to reset the voltage indicator to read the 115V like before and your all set.
1helpful
Looking for a diagram on a hayward pool pump electrical wiring model super 11
What specifically are you looking for (beside the fact you asked for a diagram)?
It should be setup for 220 Volts ... the only thing inside is a start cap.
Can you tell me more? I maintain 5 2 and 1 1.5 hp such pumps.
New 1.5 hp super pump hayward, blows circuit when turned on...
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
