20 Most Recent
Hayward Pool Products HAYWARD 1.5 HP 2 SPEED SUPER PUMP - INGROUND POOL PUMP - Questions & Answers
How can you wire a 2 speed motor to run only on high
You dont really need to change anything ... just keep it in high speed. If you really want to remove the switch, remove the cover, follow the wires and comlete the circuit that is for the high speed setting. You will need a volt meter with contunity setting to complete this task.
Hayward Pool...
Answered
on Jun 25, 2012
Water leaking from superpump. looks like it is
sounds like the tank is cracked. bummer .. if you remove the motor from the tank and let the tank dry you can see the cracks as small black lines, and there is no real good patch for this, i recomend to all of my customers to sclicone the seal plate to the tank body do to the pumps poor design.. yo just might need a new tank assy there not cheap so i recommend you hunt down your local pool pump motor repair guy with free testing and see if he has a used one and how to install it so to get best performance out of it.. these guys know pumps and can save you thousands of dollhairs over the years.. a used tank $50 or less .. Jay .. Florida where the pools open 365 days a year
Hayward Pool...
Answered
on Dec 14, 2011
I need a seal for
Any pool store in your area should have a 201 mechanical seal available. If not, try looking under pump repair for a shop in your area. It is a very common seal and is interchangeable with the Hayward super pump seal so it should not be hard to find.
John
Hayward Pool...
Answered
on Jun 20, 2011
Can I save money if I buy the pump online and then
You probably can but don't. Use the online price to negotiate a better deal with the installer, then if it goes wrong they can't say "you bought the pump so it is not my responsibility" etc. Better to let the installer give you a comprehensive warranty.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Hayward Pool...
Answered
on Mar 05, 2011
Turn filter on, pump turns on then trips breaker?
NOT A MOTOR TO TAKE LIGHTLY 2 SPEEDS ARE BIG $$$ . TAKE 4-6 . 9/16 BOLTS OUT OF PUMP DISCONNECT POWER (LOOK) WRITE DOWN COLOR OF WIRES AND PLACE THEY GO TAKE PICTURE ! ! AND DO NOT TRY TO TAKE ANYTHING ELSE APART ! SEARCH FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING USE YOU ZIP CODE IN YOUR SEARCH .COULD BE JUST A BAD BREAKER BUT NOT WORTH THE CHANCE..HAVE A PRO LOOK AT IT. BEST OF LUCK .. VOTE IF'N I WAS OF HELP
Hayward Pool...
Answered
on Aug 03, 2010
When installing a chlorine pack I turned the
Probally it is your plumbing in and out of the pump has shrunk from the heat and causing it to **** air. You will need to replumb and do the pressure side of the pump at the same time as it has probally shrunk also and will leak water when you get it going. Just for good measure you should do the pump seal at the same time.
Hayward Pool...
Answered
on Jun 26, 2010
My Hayward super pump is leaking water where the
Take the two sections apart, remove the seal and put the two sections back together.You will be able to see any gaps if they are warped. A straight edge might work too. Also inspect the surfaces for any cracks. The can get a hairline crack if the sections are tightened to tight, and the seal is out of the grooves. If all is ok, silicone the seal, silicone the grooves, then put the pump back together. This will help keep the seal in place. I just use a pool/spa sealer like Leslies Pool and spa lubricant.
Hayward Pool...
Answered
on Jun 26, 2010
Haywards Super Pump Tick tack sound
You may have been running it on the wrong voltage for 3 years especiallyif you feeding it 120 volts to a 220 setup. Assuming it is getting the right voltage and it clicks off and on you run winding is bad so the start winding cliicks on to bring it up to run speed opens the switch but the run winding isnt there so it repeats the process forever till it fails.
Hayward Pool...
Answered
on Sep 05, 2009
