20 Most Recent Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Questions & Answers
Would also think pump bad.
Hayward 3/4hp... | Answered on Sep 05, 2017
Thank you for posting your question here on Fixya.com.
There should be three wires. Two of them will be the same color and the third is usually white & red. The two like-colored wires go together on one pole of the capacitor. The red/white goes by itself on the other. It does not matter white pole is which wire(s), as long as you pair the wires as described.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Hayward 3/4hp... | Answered on Apr 17, 2017
Either one. Neutral to the other post. Be sure to set the voltage change device to 115V to match your incoming line voltage.
Hayward 3/4hp... | Answered on May 20, 2016
most manufacturers suggest replacing the sand every 5yrs. when the corners wear off, the sand rounds and doesnt catch debris. it also packs faster.
if you are having short intervals between backwashing, it is a solid indication that sand needs replacing
Hayward 3/4hp... | Answered on Mar 17, 2016
it sounds like the pump is tripping the overheat relay. might be time for a new pump. depending on how far the 'tank above' is, you might not have enough pump to push water there.
needs a new motor and seals bearings are no good and you cannot replace them sometimes a new pump is cheaper in the long run
Hayward 3/4hp... | Answered on Aug 30, 2014
needs a new motor and seals sometimes its cheaper to just replace the whole pump
make sure you have clean source voltage coming in like a knicked wire touching the case, also make sure you dont have the hot wire leads touching the frame or something else
take the back off the motor change the white and brown wires as shown on the side of the motor or if it has a knob turn it to 120 volts then put the black wire on the F1 lead and the white wire on the F2 lead and the green one gets screwed to the case under the green screw
there is no float valve
Hayward 3/4hp... | Answered on Aug 27, 2014
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
108 questions posted
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Hayward Pool & Spa
  • Hayward Pool & Spa
Most Popular Question
need wiring diagram hook capacitor back
  • Pool & Spa
