The model number is 84052 i took the top off because ti thought the belt was broken because the drum would not turn. i think that the motor is broken or stalled. when i push the start button and push the drum to start it runs, but if i reset it and just push the start button i get a humming noise and the drum will not turn
A broken drive belt is the most common reason a dryer won't spin. To fix this issue, turn the drum by hand. A working belt should provide some resistance, so if the drum turns very easily and loosely, the belt is probably broken.https://www.youtube.com/watch?v=HI4JXnh-YN8
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
More than likely it is the belt. The dryer has a motor that drives the drum usind a rubber belt that has probably broken. It is fairly easy to replace. Take top off dryer by lifting up top in front, (should be hinged) then you will see if belt is on or broken. Go to local appliance store with make and model number from your dryer and then you will have to lift drum out of case and put belt around it and replace. if you cannot reach belt to put around motor from top you will have to remove back access panel. Put belt on motor and dry away. Good luck.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
You must pop off the top of the dryer then remove the front after the front is off you can remove drum . The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
THE BELT HAS BROKEN,TO REPLACE REMOVE THE 2 LINT SCREEN SCREWS,PULL THE TOP TOWARD YOU AND UP,REMOVE THE 2 SCREWS FROM THE TOP FRONT PANEL ONE ON EACH SIDE,REMOVE THE DOOR SWITCH WIRES,PULL THE FRONT UP AND OFF,PUT THE NEW BELT AROUND THE DRUM AND UNDER THE DRUM PULLEY AND ONTO THE MOTOR PULLEY,PUT ALL BACK TOGETHER,YOU CAN GET THE MODEL NUMBER FROM INSIDE THE DRYER DOOR,GO TO YOUR LOCAL APPLIANCE PARTS STORE TO GET A BELT,OR GET IT FROM SEARS .COM
Your glides are brobably broken and missing. This will make the drum hard to turn and bind the motor. Get the front off the dryer: Start by popping the top with a putty knife. Get the screws out that hold the front on and take a look:
I could be wrong, but I don't know of a dryer that DOESN'T use a belt to turn the drum. If the motor is turning on, and the drum is not spinning, more than likely your suspicions are correct and the belt is broken. You can find a replacement at searspartsdirect.com. Just type in the model number you have provided and look under the "Tumbler" heading for item number 5 (part #341241). The website also offers some helpful exploded view illustrations to assist in part location and installation.
Repairclinic.com carries the part at a cheaper price (item number 529597). Use the part number provided by the Sears website for your search criteria. Repairclinic also offers dryer belt installation diagrams. Just click on the "Repair Help" link at the top of the page and look under the "Special Features" section on the following page for "Dryer Belt Diagrams". Magic Chef uses diagram F. I hope you find this information helpful. Let me know if you have any questions.
