20 Most Recent Kenmore 84072 Electric Dryer Questions & Answers
417.84072300 rattle noise
You will have to replace the motor.
12/9/2012 7:28:31 AM • Kenmore 84072... • Answered on Dec 09, 2012
Runs for little while then
Try taking the control board out and check for burned off traces. Solder back those points and it should work again. Just did it to mine and now it runs again. Still flashes PAU though.
10/25/2011 5:53:22 PM • Kenmore 84072... • Answered on Oct 25, 2011
I have a kenmore dry
Hello Bill,
Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will do...run whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
GENE
9/12/2011 11:07:05 PM • Kenmore 84072... • Answered on Sep 12, 2011
My dryer doesnt heat. I
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
7/24/2011 1:23:36 PM • Kenmore 84072... • Answered on Jul 24, 2011
0answers
0answers
I had a power outage
84072 is NOT a good model number.
Please post the correct model for a decent answer from the pros at FixYa. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
5/20/2011 2:02:02 AM • Kenmore 84072... • Answered on May 20, 2011
Dryer has power, buttons on front beep when
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
1/29/2011 12:55:29 PM • Kenmore 84072... • Answered on Jan 29, 2011
The tube spins, but there
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
10/15/2010 12:54:35 AM • Kenmore 84072... • Answered on Oct 15, 2010
Kenmore electric dryer--model 41784092500. When I
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9/26/2010 1:21:12 AM • Kenmore 84072... • Answered on Sep 26, 2010
It means the control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the “LOC” on the display is cleared. Locking the control is done the same way it is unlocked.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
8/23/2010 3:32:03 PM • Kenmore 84072... • Answered on Aug 23, 2010
Time to change the dryer or is it worth fixing?
this could be something as simple as a loose or stretched out belt to a jammed pressure roller to a bad motor. could also be the drum is not mounted right due to worn out or missing felt pads and is causing a binding at the front or rear of the unit.
8/6/2010 2:36:09 PM • Kenmore 84072... • Answered on Aug 06, 2010
Dryer not heating up
Please follow link below and check if the dryer is heating or not
http://www.youtube.com/watch?v=fP9pmbw6PzQ
Hope it helps.
7/22/2010 9:27:04 AM • Kenmore 84072... • Answered on Jul 22, 2010
Kenmore 84072 dryer runs doesn't heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
6/6/2010 11:24:08 PM • Kenmore 84072... • Answered on Jun 06, 2010
Heating element is going out it work about ten
It may be your heating elements, but I would check your circuit breaker to make sure its putting out 110V on each phase as the heating elements are the only part in your dryer that use 220V, so if the circuit breaker is not outputing enough voltage that could be your problem (it's also a less labor intensive fix). NOTE: IF YOU ARE GOING TO REPLACE YOUR CIRCUIT BREAKER TURN OFF THE MAIN BREAKER TO HOUSE TO POWER DOWN THE BUSS BAR THAT THE BREAKER IS PLUGGED INTO.
5/5/2010 11:53:40 PM • Kenmore 84072... • Answered on May 05, 2010
Push start but no go -- belt is fine-drum spins.
need to check the start switch, with a reader!!!! or by past it, or call a proffesional
3/9/2010 6:31:31 PM • Kenmore 84072... • Answered on Mar 09, 2010
Kenmore 84072 Electric Dryer Logo
Popular Tags
39 questions posted
Top Kenmore Dryers Experts
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
kenmore electric dryer model
  • Dryers
