Yester day i bought the psp i turned it on and i playeed gamess then i turned it off to charger it it did charge then i take the charger and put it back again it didnt charge please help me and it did not turn on
i do believe you have burnt out the inverter within the system :( i dont have an answer for you on how to persue a fix but i do wish you good luck .......keep in mind these are very cheap new nowadays so dont pay a big amount to fix it if possible ok :)
Try keeping your psp battery in a dry place for a day,then try charging.If this doesn't work.. Try the following: a) Try charging using a usb cable... c)Also try cleaning the usb port and power port or the place were u connect the charger to psp... b) Remove ur psp battery and plug in the charger and turn on the psp... When it turns on put the battery back in (do not turn off the switch or psp when u put the battery back in)...
Probably, either the battery or the charger is busted. Try borrowing a friend's PSP charger and plug it in. The power led of the PSP should turn orange when charging. If it still does not charge, you might need to replace the battery.
It could be a bad battery or you can check under the psp if you can turn it on and make sure that under Settings > System Settings > USB Charge is set to on. If it is and it isn't charging then it's a bad battery.
this is easy i solved it! buy a charger from gamestop that you have to take the battery out and then put it in the charger and charge it that way! that way if your fuse inside your psp is out it will charge the battey without putting it in the psp so all you do with the item is: take your battery out, put it in the alternative charger from gamestop (does not come with psp slim 2001 or 2000) plug the charger in the while charge the battery then bam!! there you go problem solved have a fun time playing your psp!
Did you charge it first? You need a good initial charge. Depending on the charger, it could be about 6 hours.
Also, remove the battery and check the metal contacts on the top and make sure that they are not covered by anything. Some come with a film to protect them.
i wanted to do that but the light for charging is not flashing
