I am not sure about the mac side but do not do it via a hub do it direct to a USB 2,0 compliant port.
And only use the vable that came with it not just one that fits.
not all cables are equal
Should be i know but its not always the case
If the mac has any power saving options esp for individual bits of hardware (lots of hardware have their own power saving functions) then turn them off windows allows pc users this option.
It's likely that your map (data) got corrupted. You can recover by restoring your back-up copy of the map (that you'd previously done via TomTom HOME on your computer).
If you don't have a back-up copy, try using your computer's disk check utility to fix the file system and recover data (from the storage media on your GPS device). Just connect the GPS to your computer, no need to use TomTom HOME, just use the Properties tab and use the Tools to run a disk check (assuming you're using Windows).
If that doesn't work, you may want to purchase & download and install the latest copy of the map from the TomTom website (via HOME).
