20 Most Recent Tomtom ONE 130 GPS Receiver Questions & Answers
Go to display preferences and select 'show speed limits'
Tomtom ONE 130... | Answered on Jul 17, 2014
go into your setings and select the picture you whant and put it as your wall papaer
Tomtom ONE 130... | Answered on May 27, 2014
In the Map view, tap anywhere near the center of the screen. A new screen is displayed showing a wrench/spanner. That is the Changes.Preferences. Tap the wrench/spanner to change preferences. Keep tapping the arrow on the right until you see an icon with flags of UK, the Netherlands and Germany. You may have to tap the arrow 6 or 7 times. Tap that icon to get to the alphabetical list of available languages. Select your favorite tongue (whatever that may be), and Tap the button DONE (the button at the button and to the right.
Tomtom ONE 130... | Answered on Dec 20, 2013
The TomTom One 130 model does not have built in bluetooth. You can verify this here http://www.tomtom.com/en_us/products/tomtom-outlet-store/one-130-refurbished/#tab:highlights
Tomtom ONE 130... | Answered on Sep 24, 2011
So you've got that brand new shiny TomTom, turned it on, and .... OOPS! ... somehow you've selected the wrong language. Suddenly the entire interface is (literally) in some foreign language and you can't figure out how to get back to English. This has happened to quite a few people recently, so here is a short tutorial on how to get back to US English.TomTom Main MenuIf the device is currently turned on and you are anywhere but the primary map/driving view, it might be helpful to turn the device off. Then you can turn it back on to get yourself to the map/driving view. Now click anywhere on the map to take you to the Main Menu. Depending on the language you picked and your device, it should look something like the image on the right. Click on the wrench icon (highlighted in red here) which will take you to the 'Change Preferences' menu.TomTom Change LanguageNow that you are in the Change Preferences menu, keep tapping on the right arrow button to cycle through the menu until you see an icon with three flags on it. That is the 'Change Language' button. Click on that button to bring up a list of the languages installed on your device.TomTom English USUse the arrow keys up and down to find your language, likely 'English US' for most readers of this site. A dialog will appear asking "English US?" at which point you will say 'Yes'. Presto, change-o, you are back in busines
Tomtom ONE 130... | Answered on Sep 18, 2011
There is a small hole near the docking base , insert a pin to reset the unit. Holding down the power button will never reset the unit.
Hope this helps. thanks
Tomtom ONE 130... | Answered on Apr 10, 2011
Hi Aggie.
First try doing a soft reset. This is simply done by holding down the start button for about 15 seconds.
If that does not help, you will need to connect the TomTom to your computer USB port and to install again the TomTom system.
Here the steps from TomTom:
Before you begin, make sure you have the latest version of TomTom HOME installed on your computer.
Part 1: Remove the current application
1. Reset your device.
2. Connect your device to your computer using the USB cable or dock.
3. Turn on your device by pressing the power button for 5 seconds.
  • Your device should automatically connect to the computer upon reset. If your TomTom device asks you if you want to connect to your computer, tap YES.
4. TomTom HOME may run automatically when you connect your device. If it does not, run TomTom HOME on your computer.
5. In the Main Menu of HOME click on Manage my device.
2352_01_us.gif 6. Click on the plus symbol homeplus.gif next to Applications. Click in the checkbox home_checkmark.gif on the right to select the application.
7. Click on Remove items from device.
8. Click OK at the prompt.
9. You will see a prompt, asking you to save a copy before you delete it. Choose Don't copy.
10. The application will then be removed. Click Done when complete.
Part 2: Reinstall the TomTom Application
Regards.
Ginko.
Tomtom ONE 130... | Answered on Mar 05, 2011
You can follow this steps in resetting your unit.
Press and hold the On/Off button until your device restarts. This can take more than fifteen seconds.
Tomtom ONE 130... | Answered on Jan 03, 2011
Gps 130 is supposed to hybernate only. It is almost impossible to turn it completely off.
Tomtom ONE 130... | Answered on Sep 25, 2010
You can try to reset your gps. To do this, press and hold the Power button for fifteen seconds. Release the Power button when device begins to start.
You can download the user manual from this link.
Hope this helps.
Tomtom ONE 130... | Answered on Jul 14, 2010
sounds like you have dis logged the speaker try taking the unit appart and re align the speaker as to were it is suppose to be
Tomtom ONE 130... | Answered on Jul 03, 2010
mcdevito75 here, It should be reset at settings.
Tomtom ONE 130... | Answered on Jun 26, 2010
mcdevito75 here, You should be able to contact Tom Tom online, you can also try any store that sells GPS such as staples, for advise.
You can download the user manual for this unit from this link for you to have a copy and save it to your computer for future use.
http://www.retrevo.com/support/TomTom-One-130-GPS-manual/id/20630bh334/t/2/
Tomtom ONE 130... | Answered on Jun 15, 2010
This may or may not help you.  If you are in area where the unit cannot get a signal it will tell you recalculating or if you are in area where it's maps are not up to date it may tell you the same thing. One other possible solution, shorten the trip, on a long trip the unit will/might find several possible routes and based on your settings it is unable to select just one route so it is choosing between two at the same time and it will keep recalculating until circumstances allow it to decide on just the ONE route.  Change some of your settings in the setup screen and see if that helps or if it is a long trip, break the trip up into smaller segmants. Hope this helps
Tomtom ONE 130... | Answered on Jun 01, 2010
Tomtom ONE 130 GPS Receiver Logo
99 questions posted
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Ekse
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
View Most Popular
One Tomtom
  • One Tomtom
Most Popular Question
supply battery tomtom1 in south africa
  • GPS
