Okay here is the problem with my Benq FP71G+. When I switch it on the monitor displays benq then shows my desktop for about 1 second and goes blank.The led remains lighting green.
This kind of trouble is very common to all LCD monitors. your inverter is shutting down. please check all capacitors at the power supply some are badged or blown on top due to hot pressure inside.
I had a similar problem. I replaced the the 2sc5707 transistors. ( I had to use MJE3055T instead because I couldn't find the originals.)
It now works OK for a couple of hours before it seems to overheat and switch off again.
Check the joints on the transformers - apparently they're often dry.
Go to a service center. it is not a problem what you can solve by your self. the monitor's built in power supply is damaged.
Shenzhen VIIV Technology Co., Ltd is an expert at PCB,PCBA and Rigid Borad manufacturer based in shenzhen China.
Yahoo: viivtechavril SKYPE: viivtech Mobile: 86)15989403359 Email:[email protected] ,[email protected] Website :www.szviivtech.com Tel: 0086 755-29477736 Fax: 0086 755-29410695 ADD: sha
I just got my Diploma in electronic engineering (city and guilds) so I may be able to fix the problem myself.
I just need to know what is the cause of such a problem.
Yes, I discharged all the caps...lol
Electrolytic Capacitors hold a charge for weeks, sometimes months. They should be -> Correctly discharged, before operating on a unit that contains them. Like a power supply for an LCD monitor. They could discharge to you!
