I have a frost proof outdoor faucet that worked last year, but this year the handle won't turn. I removed the handle and the packing nut, but I can not get the valve assembly to turn or come out. Any suggestions? I am willing to replace it and more than capable of doing the work, but what do I do if the valve stem assembly won't come out? Do I have to cut the pipe in the house? I've never dealt with this type of faucet before. I have a second outdoor faucet on the other side of my house, but that's a long ways to run a hose. Any suggestions would be greatly appreciated!
Odd that it worked last year, but not now AND that it has completely frozen in place.
The packing nut is all that holds the stem/valve. Try to dig out the packing material (rubber or graphite). Likely the packing material is what is preventing removal. Then put the handle back on (leaving packing nut off) and try turning and moving the handle/stem. Basically you need to pull harder.
Testimonial: "Sadly I already got that out of there and it still won’t come out! It wobbles around a bit but won’t budge, even after completely drowning the thing in WD-40. I tried shoving a shish kabob skewer in there to see how far back it goes. That thing went in well over a foot. The handle is plastic so I am considering trying to find a metal handle so I can get a better grip on it. If that doesn’t work I will be cutting down a bunch of foam from the basement ceiling and hoping they didn’t completely block the thing in with concrete. It’s an old house. People have done some strange things over the years."
I found this site and thought it might help you with your problem;
https://www.levcocare.com/2013/01/10/frost-proof-faucets-wk-2-2013
Testimonial: "That helped a little. Made me realize the packing wasn’t out. It was pushed in a bit further than expected. Sadly, I still can’t turn the handle or pull the thing out."
Here is another site and it shows some with a thread at the end near thevalve seat;http://sepenna.info/frost-free-outdoor-f...
Like the 1 below
SOURCE: How to remove the corroded valve seat housing in my tub faucet
Some seats ae rremovable and some or not Some take a hex(allen) wrench and some take a square (seat removal tool) Most of us use a seat grinder. (another tool to dress up the seat (Remove material) past the seat damage. You will find any of these tools at any hardware store that sells plumbing parts. If the seats have a square or hex hole remove and replace rather that grind(dress)the seat. All right hand threads meaning turn counter clock wise to remove. Take old seat to the American Standard plmbing supply outlet and then will match it up. Good fix-in to ya.
SOURCE: replace delta single handle shower cylinder
Yes, I believe this unit uses a cartridge right? They do fit a little tight due to the small washers on the back side of the cartridge. If this is the one I'm thinking of, there are two leg like appendenges that come off the back and fit into small holes at the back of the manifold or what some call mixing valve housing.
SOURCE: Speakman shower faucet washer replacement
Keep unscrewing, to the left. Past the point that would normally be the full "on" position for the valve. I've just removed my Speakman Kent shower stem, and because it is damaged where the washer attaches, will have to replace it (both of them).
SOURCE: i have a 2 handle bath faucet and am trying to
righty tighty, lefty loosey. if its too tight for wrench youll need a deep socket wrench that will fit it.my hats off to you. kohler makes a good faucet,if stem is shot you can find new ones at lowes.seat is also replaceble
SOURCE: Leaking frost proof hose valve, 12".
They make a repair kit with new washers and seals available at plumbing supply stores
