20 Most Recent Armstrong ASTRO-30B CIRCULATOR PUMP Questions & Answers
What challenge did Lance Armstrong face
Gee, that's a toughie, Bob..... To take performance-enhancing drugs, or not to take performance-enhancing drugs.? .........A* to me
3/14/2018 12:53:30 PM • Armstrong... • Answered on Mar 14, 2018
2answers
Life of niel armstrong
Google him
10/28/2017 4:32:44 AM • Armstrong... • Answered on Oct 28, 2017
ArMstrong model eg6g75dc10-4 serial A11148KNA
That unit is not even listed on Armstrong website.
10/5/2015 11:04:10 PM • Armstrong... • Answered on Oct 05, 2015
Hot water circulation pump not working
Check power to the pump.
10/3/2013 8:56:39 PM • Armstrong... • Answered on Oct 03, 2013
I have an Armstrong Astro 25BS recirculating pump
The most common problem with these circulators is that the stator gets stuck and does not turn.
Sometimes you can take out the four bolts on the corners and pull the motor off. Get the stator freed up again and it will work. Make sure to turn the water off before dissassembling the pump. Hopefully you have valves do you can isolate the pump.
Also check that the impeller has not broken off the end of the shaft, that also happens sometimes.
You can check the cap. with an OHM meter by switching the terminals with the test leads and the resistance should count down to zero with each switch of the leads on the terminals...if not it is bad, but replacement of the cap. may not fix the pump usually it is a secondary failure...
If you can't get the pump ot work after taking it apart and making sure it turns freely then I would replace the pump.
Heatman101
12/29/2009 2:59:14 PM • Armstrong... • Answered on Dec 29, 2009
How to wire to 120v and thermostat on a armstrong
A line voltage thermostat is just like any other type of switch, except that it's controlled by temperature.
Just wire the 120vac to the pump, but interrupt the hot (black) wire with the thermostat.
Let me know if you need more help.
10/30/2009 5:46:08 AM • Armstrong... • Answered on Oct 30, 2009
Armsrtong 1/12 horse pump noise
I bled air from the rads attached to the system and now the noise is gone from my circulator pump
12/4/2008 10:41:51 AM • Armstrong... • Answered on Dec 04, 2008
Sink faucet has little pressure all others are fine
  1. Check the aerator: The aerator is a small mesh screen located at the end of the faucet spout. Over time, mineral buildup can clog the aerator and reduce water flow. Unscrew the aerator from the spout and clean it with a toothbrush and vinegar or a solution of water and baking soda. Rinse it thoroughly and reattach it.
  2. Check the supply valves: Make sure that the supply valves under the sink are fully open. Turn them off and on a few times to loosen any debris that may be stuck in the valves.
  3. Check the water pressure regulator: If your home has a water pressure regulator, it may be malfunctioning. A faulty regulator can cause low water pressure in certain areas of your home. Contact a plumber to check and replace the regulator if necessary.
  4. Check for leaks: Check for leaks in the pipes under the sink or in the supply line. A leak can reduce water pressure and cause other problems.
  5. Call a plumber: If you have tried these steps and the problem persists, it may be time to call a professional plumber. A plumber can diagnose the problem and recommend the best course of action to restore normal water pressure to your sink faucet.
3/1/2023 4:49:04 AM • Plumbing • Answered on Mar 01, 2023
Sta-rite mse-7 vertical jet well pump will not prime.
If your Sta-rite vertical mse-7 pump will not prime, there are a few things you can try to troubleshoot the issue:
  1. Check the water level: Make sure the water level in the pool or spa is high enough to reach the skimmer and the pump. Low water levels can cause the pump to lose prime.
  2. Check the skimmer basket: Make sure the skimmer basket is clean and free of debris. A clogged skimmer basket can restrict water flow and prevent the pump from priming.
  3. Check the pump lid O-ring: Make sure the pump lid O-ring is in good condition and properly seated. A damaged or misaligned O-ring can cause air leaks and prevent the pump from priming.
  4. Check the suction plumbing: Check the suction plumbing for leaks, cracks, or other damage. Any air leaks on the suction side of the pump can cause loss of prime.
  5. Check the impeller: If the impeller is damaged or clogged with debris, it can prevent the pump from priming. Remove the pump basket and inspect the impeller for damage or debris. Clean or replace the impeller as needed.
  6. Check the pump seal: If the pump seal is damaged, it can allow air to enter the pump and prevent priming. Inspect the pump seal for damage and replace it if necessary.
If none of these troubleshooting steps resolve the issue, you may need to call a professional pool service technician to diagnose and repair the problem.
2/28/2023 6:01:54 AM • Plumbing • Answered on Feb 28, 2023
My Rohl swivel faucet R777V3 won’t swivel what do I do to repair it?
it will be from corrosion build up and faulty sealing rubbers best fix is to replace it with anew one
2/27/2023 2:48:17 PM • Plumbing • Answered on Feb 27, 2023
Black water comes from bathroom faucet when turned on for a secound
If black water comes out of the bathroom faucet when you turn it on, it could be an indication of a serious problem with your plumbing system. Here are some steps you can take to address the issue:
Turn off the water supply:
The first step is to turn off the water supply to your home. This will prevent any more black water from coming out of the faucet.
Identify the source of the problem:
The black water could be caused by a number of factors, such as rust in the pipes, sediment buildup, or contamination. It is important to identify the source of the problem before taking any further steps.
Flush the system:
Once you have identified the source of the problem, you can flush the system to remove any sediment or rust buildup. Turn on all of the faucets in your home, including the one that was releasing black water, and let the water run for several minutes. This will help to clear out the pipes and remove any debris.
Call a plumber:
If the problem persists after flushing the system, or if you are unable to identify the source of the problem, it is recommended that you call a licensed plumber. A professional plumber will be able to diagnose the problem and recommend the best course of action to resolve it.
In summary, if black water comes out of your bathroom faucet, it is important to turn off the water supply, identify the source of the problem, flush the system, and call a plumber if necessary.
Ofcourse it’s best to call a professional
2/23/2023 9:29:22 PM • Plumbing • Answered on Feb 23, 2023
My kwc kitchen faucet doesn't swivel
Is the Tap body in 2 parts or is it just 1 solid body?
2/18/2023 7:13:54 PM • Plumbing • Answered on Feb 18, 2023
How to remove Arbor single handle Dome (kitchen faucet)?
  1. Turn off the water supply valves under the sink.
  2. Turn on the faucet handle to release any water remaining in the lines.
  3. Locate the set screw on the handle or the underside of the dome, depending on the faucet model.
  4. Use an Allen wrench to remove the set screw by turning it counterclockwise.
  5. Once the set screw is removed, grip the dome or handle with your hands and pull straight up to remove it from the faucet body.
  6. If the dome is difficult to remove, you may need to use a strap wrench or pliers to loosen it before pulling it off.
  7. After the dome is removed, you should have access to the faucet cartridge, which can be replaced if necessary.
It's important to follow the manufacturer's instructions for your specific faucet model, as the steps may vary slightly depending on the design. Additionally, it's a good idea to have a bucket or towel handy to catch any water that may drip out of the faucet during the removal process.
2/16/2023 9:26:09 PM • Plumbing • Answered on Feb 16, 2023
My ITT Magna pump LD7AC pressure switch will not stay on or keep jets running. Whats the fix?
The ITT Magna pump LD7AC pressure switch is used to control the pressure in a water system. If the pressure switch is not staying on or the jets are not running, it could indicate a problem with the pressure switch or the water system. Here are some potential solutions to try:
  1. Check the air pressure: Make sure that the air pressure in the pressure tank is set correctly. If the air pressure is too low, the switch may not stay on.
  2. Check the pressure switch: Make sure that the pressure switch is properly adjusted and not damaged. The switch should be adjusted to turn on at the correct pressure and turn off at a slightly lower pressure.
  3. Check the water system: Make sure that the water system is not losing pressure. This could be due to a leak in the system or a clogged water filter.
  4. Check the electrical connections: Make sure that the electrical connections are secure and not corroded. Loose or corroded connections can cause the switch to malfunction.
If these solutions do not resolve the issue, it may be necessary to seek professional assistance to diagnose and repair the problem. A qualified technician will be able to diagnose the issue and repair the pump or pressure switch as necessary.
2/12/2023 12:59:16 PM • Plumbing • Answered on Feb 12, 2023
Everpure faucet leaks at handle, how to fix ??
If your Everpure faucet is leaking at the handle, the problem could be a faulty O-ring or a worn-out cartridge. Here are the steps you can follow to fix the leak:
  1. Turn off the water supply: Before you start working on the faucet, make sure to turn off the water supply to prevent any accidents.
  2. Remove the handle: Use a screwdriver to remove the screw that holds the handle in place. Once the screw has been removed, you can gently pull the handle off the faucet.
  3. Check the O-ring: Look for an O-ring around the base of the handle. If the O-ring is damaged, worn or missing, it can cause water to leak from the handle.
  4. Replace the O-ring: If the O-ring is damaged, replace it with a new one. You can purchase O-rings at a hardware store or online.
  5. Check the cartridge: If the O-ring is in good condition, the problem could be a worn-out cartridge. You may need to remove the cartridge and replace it with a new one.
  6. Reassemble the faucet: Once the O-ring or cartridge has been replaced, reassemble the faucet by putting the handle back in place and tightening the screw.
  7. Turn on the water supply: Finally, turn the water supply back on and test the faucet to see if the leak has been fixed.
If you're having difficulty fixing the leak or if the problem persists, it may be best to contact Everpure customer support for further assistance. They can help you diagnose the problem and recommend the best solution.
2/12/2023 10:35:06 AM • Plumbing • Answered on Feb 12, 2023
Onga Water Switch pump not engaging consistently and turning on and off throughout watering cycle.
It sound like you may be in fault mode. This unit is not known to us in North America. Make sure your tank level switch is operating correctly and also make sure there are no airlocks in the pump. Page 14 onwards. These units can be serviced by Pentair, as they are an expensive unit to buy https://www.onga.com.au/_repository/1/documents/L100195_0719_Waterswitch_OM.pdf https://www.google.com/search?q=onga+water+switch+pump+cleaning+instructions ..
2/6/2023 10:51:33 PM • Plumbing • Answered on Feb 06, 2023
Why does touchless water faucet only work when other faucet turned on?
It's possible that the solenoid valve in the touchless faucet is not functioning properly, and needs to be replaced. Another possibility is that there is a loose or broken wire in the electrical circuit that powers the solenoid valve. You may want to check the connections and wiring, and consult a plumber or electrician if necessary, to help diagnose and repair the issue.
1/29/2023 12:55:57 PM • Plumbing • Answered on Jan 29, 2023
I purchased a house that has a flotec laundry tray system Model #S1800v-03 and noticed it is leaking where the top and bottom case connect with screws.
It's possible that the gasket between the top and bottom case has worn out and needs to be replaced. You can check the manual for the system or contact the manufacturer for more information on how to replace the gasket. It's also possible that the screws need to be tightened to prevent the leaking. If the pump is not turning on, you may want to check the float switch and make sure it's functioning properly.
1/29/2023 12:54:31 PM • Plumbing • Answered on Jan 29, 2023
Armstrong ASTRO-30B CIRCULATOR PUMP Logo
2 questions posted
Top Armstrong Plumbing Experts
john h
Tom Chichester
Are you an Armstrong Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Armstrong Plumbing
  • Armstrong Plumbing
Most Popular Question
furnace shuts off
  • Plumbing
