20 Most Recent Moen 6610 Brantford Two Handle Lavatory Faucet with Drain Assembly Chrome Questions & Answers
It usually takes a special tool to remove a Moen cartridge. Just getting the handle off can be tough. How long have you had this unit? maybe it would be cheaper just to replace the whole thing. My last Moen lasted a good twenty years, still working good, but finally starting to corrode. Good product.
Moen 6610... | Answered on Dec 01, 2013
This should help you http://www.moen.com/shared/docs/exploded-parts-views/6610pt.pdf
And yes it can be a little bit of a job. If the faucet has been around a while you mite try some white vineger on the cap to looson the lime deposits.
Moen 6610... | Answered on Jul 14, 2011
contact moen for replacement parts. have your model number ready
Moen Plumbing | Answered on Nov 19, 2020
First clean out your cabinets under the sink. Second turn turn the cold water valve off, hot water valve as well.
You should be able to locate the sprayer hose as it will have a weight on it, this helps to pull the sprayer back when you are finished with it. Remove the weight by lifting up on the tab should be on the center of the weight.
Then you should see the hose connection.There you should see a button.Push it in and give it a little tug. The hose should be disconnected. Just follow in reverse order to reinstall.
I hope this is information is helpful. Have a blessed day.
Moen Plumbing | Answered on Nov 06, 2019
Moen 6610 Brantford Two Handle Lavatory Faucet with Drain Assembly Chrome Logo
10 questions posted
Top Moen Plumbing Experts
john h
Bruce Robin
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Moen Plumbing
  • Moen Plumbing
Most Popular Question
moen brantford bathroom faucet one
  • Plumbing
