SOURCE: Huskee drives weird
If the belt is fine and it isn't slipping at all then the problem would be inside the hydramatic trany. It isn't serviceable and would cost more then the tractor is worth.
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
SOURCE: Craftsman lawn tractor mower,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
SOURCE: parked on steep hill have to give a lot of gas
Are you driving an automatic? It sounds like the clutch plates inside your transmission may be slipping. Yes, automatics have small clutch plates between each gear whereas a standard has one big clutch plate
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Please add details in the comment box...
Model number?
