20 Most Recent Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Questions & Answers
2answers
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
1/21/2023 8:37:19 PM • Husqvarna Forest... • Answered on Jan 21, 2023
3answers
Husqvarna 345 chainsaw will not start. It is 3
I suspect she is flooded. Flooding is the most common cause of fails to start on a chainsaw. Remove the plug I bet it's wet.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
I've a 359 one time I forgot to pull then push the choke (sets fast idle). My shoulder gets sore just thinking about it.
1/24/2019 5:23:29 PM • Husqvarna Forest... • Answered on Jan 24, 2019
5answers
Husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
1/16/2019 3:57:25 AM • Husqvarna Forest... • Answered on Jan 16, 2019
Spark plug gap on husky 350 chainsaw
The plug should gap at 0.5 mm or .020" and be sure to use the proper resister plug. Do not cross reference a plug.
4/27/2015 8:27:34 PM • Husqvarna Forest... • Answered on Apr 27, 2015
Where are the screws on carburator for my chain saw
Remove the air box and air filter. The 2 screws holding on the carburetor are right on the outside of the carburetor. The screws go through the carburetor through the intake boot and into the cylinder.
4/27/2015 7:51:15 PM • Husqvarna Forest... • Answered on Apr 27, 2015
2answers
Chainsaw wen warms up bogs down, wants to die cutting into wood
Could be running too lean, Should be runnning 50:1.
11/26/2014 8:26:58 AM • Husqvarna Forest... • Answered on Nov 26, 2014
Where can I find a husqvarna 240 e carb adjust tool ?
Before I change carbs, I think I would change fuel lines. Also always use ethanol free fuel.....the ethanol will eat and clog your lines!
7/12/2014 9:35:05 PM • Husqvarna Forest... • Answered on Jul 12, 2014
Saw dies when cutting into wood
If it revs up fine with no load try cleaning or replacing the air filter
11/5/2013 10:59:13 PM • Husqvarna Forest... • Answered on Nov 05, 2013
Adjust carb on a sthil 011
Adjust the carb using the two tuning screws marked H & L. The other one adjusts the idle speed 'tick over'
8/6/2013 7:14:41 PM • Husqvarna Forest... • Answered on Aug 06, 2013
3answers
Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
4/14/2013 4:12:52 AM • Husqvarna Forest... • Answered on Apr 14, 2013
2answers
I have a husqvarna model 50 chain saw and am not
Husqvarna Rancher 50 1982-11 OM Follows:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS1982/HOUS1982_O8200003.PDF
50:1 according to your manual if using Husqvarna (quality) 2-cycle oil.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
3/30/2013 3:32:32 AM • Husqvarna Forest... • Answered on Mar 30, 2013
Cant remove plastic covers on L andH screws on my 350 husky
If your refering to the Walbro carb and the little red anti tamper caps then they can be a pain. If you look carefully they have a little tab that sticks out of them and this must line up with the cut out on the carb in order for them to be removed. I use a pair of long nose pliers to take them out, but if you're not fussed about putting them back on then just keep unscrewing the tuning screws, They will eventually break the caps and come out with the tuning screws.
3/17/2013 7:47:52 PM • Husqvarna Forest... • Answered on Mar 17, 2013
Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
78 questions posted
Top Husqvarna Garden Experts
Dwain Pippen
Jay Finke
Jay Finke
Marvin
Marvin
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
husqvarna chainsaw carburetor adjustment
  • Garden
