20 Most Recent
Husqvarna Rz4623 46" Ztr Lawn Mower Zero Turn 23hp Kohler Engine Questions & Answers
Mover sometimes does not move and other time moves real slowly
ck belts that run hydraulic pumps for tire drive , it might have slipped a bit with chain caught , now belts skid instead of transferring power to pumps , also these pumps might have a manual pressure relief reset , I was thinking they only used them on bigger units , but you might have one as well ,hey its possible , this will need to be reset prior to continuing mowing (refer to manual for location )
While mowing the blades disengage and engage ?
Is this just when you pull the steer lever into reverse ? Most are made that way and I think the newer ones offer a bypass on them to stop that. The old one just get a jumper wire on each steer lever to stop it.
My RZ4623 will not move.
If the unit stopped moving at once. I suggest checking the belt. It is very unlikely both Hydro-Gear units would fail at the same time. check under the mower, and check on top of the transmissions, you should see the drive belt running between both transmissions and the engine.
