Computers & Internet Logo
Posted on May 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magnavox mdr513h/f7, if i do the reboot, Unplug player for 2 minutes, now press and hold power for 30 seconds and release, plug back in and try again will I loose my programming?
Raj Patel
Level 3:
Genius:
  • Master 1,042 Answers
  • Posted on May 27, 2019
Raj Patel
Master
Level 3:
Genius:
Answers
1042
Questions
Helped
270595
Points
3723
The settings listed below will remain unchanged even after resetting to the factory default. - Language setting - Channel setting - Clock setting - Parental lock setting - V-chip setting - Timer programming information
Testimonial: "Thanks, that answered my question, allowing me to proceed. Alan"
5 Related Answers
Anonymous
  • Posted on Oct 15, 2008
SOURCE: Computer freezes up. Only unplug power cord can I reboot the computer.
  1. Dell suggests upgrading audio drivers and flashing bios.
  2. I did both of these and problem reappeared after a while.
  3. Then I removed heatsink/fan assembly,cleaned all surfaces,applied good quality silver-loaded heatsink compound and reassembled
  4. PC has been running for more than a day with no probs so far
Anonymous
  • 14 Answers
  • Posted on Dec 31, 2008
SOURCE: ACER power 1000 has no power at all
change the power supply, if still nothing then motherboard might be gone
Anonymous
  • Posted on Feb 03, 2009
SOURCE: my kitchenaide javastudio stopped working
Err2 is a failed heating element. There is no fix or replacement parts sold. I was lucky I had a receipt, even out of the year warranty they(KitchenAid) are still replacing it.
Anonymous
  • 3197 Answers
  • Posted on Sep 14, 2009
SOURCE: 2006 Honda Accord Garage door Homelink Program with Chamberlain
useful info.
Anonymous
  • 6 Answers
  • Posted on Jan 03, 2010
SOURCE: My Magnavox plasma screen tv, model number:
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Vizio smart tv has barcode on the screen
Try a reset, unplug the TV, then press and hold the power button ((on the TV set)) for 30 seconds, then release it. Then wait 10 minutes and plug the set back in, press and hold the power button again on the set until it turns on.
2answers
RESTORE FACTORY SETTING
Press and old the reset button on the router for 20 seconds. Release the reset button. Wait for 30 seconds. Power cycle the router.
See How to reset Linksys router to factory default settings.
Also watch video
4helpful
Magnavox DVD recorder VCR DVD will not open
Unplug player for 2 minutes, now press and hold power for 30 seconds and release, plug back in and try again, if no! it must be dismantled to recover the disc.
Acer 5749 touchpad does not respond nor does Fn+ F7 or rebooting to factory standard, any ideas ?
Unplug charger from computer, remove the main battery, press power on and hold for 30 seconds and release. Let the laptop sit for 30 minutes, plug battery back in, plug the charger back in and power on, hopefully this resolve issue.
6helpful
6answers
3 month old magnavox mdr515h/f7 is dead. It may be under some warr. Had power go off during a storm last night. Unit was plugged into a surge strip and other items on it are ok. don't know if it quit then...
My unit was dead also.....So I checked outlet first...It was good....Then I tried the 10 minute disconnect and reconnected unit......Saw Unit had power on LCD screen....Hit ON button on remote after changing to HDD and unit works perfectly again....That fix saved me 75 bucks for repair center to do same thing...Glad Funai makes units that shut off before damage occurs...Unit just needed to cool down hard drive or circuitry before it sensed it was ok again....When plugged in it is still technically powered even tho you dont see it on the LCD screen of the unit...
2answers
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
10helpful
2answers
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
Wireless stopped working. If correctly plugged
Have you tried a hard reset, then setting up the wireless again?
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
312helpful
17answers
My 32" sharp lcd doesn't respond to the remote
Ok I just dealt with the Sharp customer support for this problem. 1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
... let me tell you I thought the lady was crazy when she was telling me this but it worked!
2answers
Factory settings
Step 1 Power the unit off by unplugging its power adapter. Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure. Step 3 Power the device back on by plugging it in. Continue to hold the reset button. Step 4 Watch the lights on the front of the router. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button. The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, unplug the power on the router and plug it back in. If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
Top Power Computers & Internet Experts
vince
NOEL
NOEL
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
