SOURCE: cuisinart food processor DLC 8 Plus - can't unlock new bowl
I just had the same problem! I gently tapped the the bottom of the handle with a hammer in a clockwise direction. It finally unlocked and is now working fine. Good luck!
SOURCE: Need to fit new switch assembly
Only two screws ?? this must be an older magimix 5000 machine, does the replacement part have a 10mm frame around or flush, the part you need is click here http://www.magimix-spares.co.uk/On-Off-Pulse-switch-with-frame-5000---5100-Chrome/product/101296/
SOURCE: cuisinart DLC-8 Plus Motor Shaft Cover broken.
I wrote in December with my problem and went on the web sites mentioned. A cover only cost $69.00. A new bowl and cover was $99.00. I only needed the cover. The new cover did not work and I ended up going to Macy's when they had the DLC-8S on sale for $99.00 and bought a new one. I took my blades with me and they fit the new machine. DON'T WASTE YOUR TIME AND MONEY (unless you find an old machine at a yard sale) THE PARTS COSTS AS MUCH AS A NEW MACHINE ON SALE. ees
SOURCE: I cannot remove the top from the base
I don't know what brand food processor this is. However, are you saying that the bowl will not rotate to release? It's normally just a matter of twisting the bowl (probably anti clockwise when viewed from the top) in order to release it.
SOURCE: My model number is FP1450
my model # is FP1450 and it's a black and decker quick N easy food processor. I'm looking for a replacement slicing/shredding blade. where can I get this?
