20 Most Recent Cuisinart DLC-10S Pro Classic Food Processor Questions & Answers
I have a DLC7pro from around 1982 that I just replaced the sheath on.
To remove the sheath I use a small pipe cutter and took the sheath off in approximately ½ inch sections. Once the circular cut was complete I used a plier to pull off the section. - This method worked GREAT! Be sure you get ALL of the white plastic off and be sure to remove the ½ inch brass "ring" which is part of the old sheath. Also, make sure no plastic "crumbs" are in the base of the shaft where the new sheath will sit. You will see that the metal shaft has a flat side. With a sharpie marker, mark the metal shaft near the base to indicate where the center of the flat side is.
When you look at the replacement sheath, you will notice flat sides on the outside of the sheath. If you look inside the sheath, you will see two "nubs", these nubs form a flat inner side of the sheath . Unfortunately these nubs do NOT line up with the flat outside sections. Use a sharpie marker to mark the center point of the two inner nubs. The inner flat side HAS to match up perfectly with the flat side of the shaft. The marker helps you do that.
Line the inner flat side of the sheath up with the flat side of the metal shaft and push the sheath on your hand as far as it will go. It should go about an inch from the base.
Put the base on a mat on the floor ( you don't want to damage your floor) . Next you will need a hammer, piece of 2x4 wood and BRUTE STRENGHT! - Please note that once you hammer this, even just one strike and the sheath will NOT come off. Put the 2" side of the wood against the top of the sheath. Using more force than you think you should need - strike the wood to hammer the sheath all the way down. It should take 3 - 5 very hard strikes. If the base of the sheath rubs on the bottom of your workbowl - they will fuse together, so be sure the sheath is seated as far down as you can get it. Again, it takes a LOT
Cuisinart... | Answered on Mar 17, 2019
Could be a defective switch or broken wire connection
Cuisinart... | Answered on Nov 15, 2017
It may be necessary to replace bowl and lid.
Cuisinart... | Answered on Sep 21, 2017
check the slot width
Cuisinart... | Answered on Aug 06, 2014
Yes. It's the basic physics of all liquids.
Perhaps a blender might be a more suitable tool?
Generally you would use the food processor for mixing/blending/chopping all the dry ingredients (and maybe the butter if you are making something like cookies).
Separately mix all the really wet ingredients together in a mixing bowl/large measuring cup.
Then combine the dry ingredients from the food processor with the wet ingredients in a mixing bowl (you can fold the dry into the wet if you used a bowl to mix the wet ingredients together. If you used a measuring cup for the wet, then it's usually better to put the dry ingredients into the mixing bowl first, making a depressed area in the center, and then add the wet into the dry.)
Cuisinart... | Answered on Jul 29, 2014
Try this link:
Food Processors Product Manuals Cuisinart com
And look for the one that generally matches the era (design) of your machine, and then the bowl size.
All the best to you!
Found it at:
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DLC-10S-_E
Go to the following website. You will find a downloadable copy of your manual there, for free:
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DLC-10C-_E
Cuisinart... | Answered on Jul 28, 2014
I am guessing that something is not seated properly. Make sure the bowl clicks when turned...drops the pin in. Make sure the top is ("clicked in") locked. If you poured something out of the bowl and went to re-use it, make sure the blade is seated properly; make sure there is no food caught under the blade hindering the blade to be seated. Everything must be locked in correctly to operate safely.
Cuisinart... | Answered on Mar 25, 2014
Possibly the micro switch which is activated when the lid is turned into position. Sometimes a particle of food gets lodged in the opening and prevents the lid from engaging the switch.
Or maybe the wires in the plug have come loose.
Cuisinart... | Answered on Nov 22, 2013
take it back to the store you bought it and they will give a new one and your money back
Cuisinart... | Answered on Aug 29, 2013
Cuisinart DLC-10S Pro Classic Food Processor Logo
66 questions posted
Top Cuisinart Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • Cuisinart Food Processors
Most Popular Question
replace motor shaft cover
  • Food Processors
