Question about Cuisinart DFP-11 Deluxe Food Processor
I plug my cuisinart and it will not start. It worked the last time I used.
Posted by gailmorgenth on
ThaMp3Doctor
  • 8,597 Answers
Put the work bowl, lid, and pusher on one piece at a time - handle of work bowl faces the front of the food processor, hollow feed tube faces the back, and the sliding lock switch on pusher sleeve faces the front. Should turn on.
If it doesn't, test the motor - remove the work bowl and other parts completely. Plug the base in and turn it on, and use a pen to push in the dark grey or black button on top of the base - if it spins, the motor is still good - you may just need a replacement part. If it doesn't make a sound, it needs to be sent in to Cuisinart for repair.
Posted on Mar 30, 2009
  • Dixie Thiery May 02, 2019
    So I pushed the button down and the motor runs but not if I don't manually push the button down...so what is the problem and how do I fix it?
Gwen Coleman
    New Friend:
Wow Thanks! I was just about to donate it. :-)
Posted on Oct 06, 2016
Gregg Burns
    New Friend:
Yup. The front little button has to be depressed by the bowl apparatus itself. If the top is already fully assembled the bowl won't lick because its already got the saftey kickstand sticking out the bottom. You won't see it standing above.
Posted on Dec 12, 2015
Josee-Juicy IO Maiden
    New Friend:
This tip was VERY helpful! Being left-handed, I was putting my work bowl the wrong way! After I took everything out to test the motor and pressed the black button with a pen, the motor worked!!!! Then I realized I was putting the work bowl backwards!!! THANK YOU!!!!
Posted on Apr 26, 2015
I can't start my brand new cuisinart 14 cup model I have it plugged into a good power source, with shoot, rod and blade in place. It won't power up! Please help!
Hillary, I have the same problem. Do you think these are the edsels of the food processors. I paid almost $200 for mine, haven't ever used it since I bought it last year. Have you resolved your problem>
Oct 29, 2011 | Cuisinart DFP-14BC Custom Food Processor
I have a Cuisinart 14 cup food processor which will not turn on
Hi-
We have a Cuisinart and these tools are very rugged- so I doubt that the motor is bad. My only suggestion would be to make sure that the safety catch is being actuated when you click the cover clockwise to secure the mixing chamber. There is a hole in the housing that the acuator pin sticks into to disengage the safety switch. Perhaps the switch is not being pressed off.
Hope this helps,
Jeff
Oct 28, 2009 | Cuisinart DLC-7SFP Pro Food Processor
FOLLOWED MANUAL INSTRUCTIONS BUT MACHINE DOES NOT START. WHEN OWNER USED IT LAST IT WORKED. ATTEMPTED TO REFIT BUT COULD NOT GET IT STARTED. MACHINE WAS PLUGGED INTO GOOD POWER SOURCE, NOTHING WRONG WITH...
One of the major problems I have seen with food processors is the safety switch, which will not allow the motor to turn on if the bowl and top are not properly seated. The lever and/or switch sometimes wear to the point that they no longer work (easily). I'd do a bit more checking before I discarded the machine.
Oct 23, 2009 | Cuisinart Food Processors
Timer works but machine doesn't turn/run
It sounds as if you may need a control board for your food processor, it could be that there is a loose or burned connection inside your unit and could be fixed by disassembling it. another option is to call the Cuisinart phone line located on the bottom of the processor or on the user manual. Unfortunately most control boards are too costly to repair or replace, and your machine is not under warranty. most times they are deemed a ``throw away``. hope this helps.
Thanks
Oct 11, 2009 | Cuisinart SmartPower Premier Duet...
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Motor works but will not turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl asssembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Motor won't turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Nov 27, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Wont run
If you try the instructions below, and the motor test fails, you can send it in to Cuisinart for a trade-in, but the trade-in will be just as expensive as getting a new food processor (unless your product has an extra-long motor warranty):
-Tha Mp3 Doctor
Sep 16, 2006 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DFP-11 Deluxe Food Processor Logo
29,060 people viewed this question
Top Cuisinart Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
