SOURCE: just got new computer with windows vista now my lexmark p6250 printer dos"t work
You will need to install Vista driver to suit, please note that orginal scanning software is not available but you will find within Vista itself the ability to scan.
Vista DRIVER Download
SOURCE: how do I clear carrier jam on lexmark p6250
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
SOURCE: Win Vista cannot print on Win XP(P) shared lexmark p6250 printer
try to remove printer driver and install again located at control panel..
how to do this?
go to the start and din control panel and din click ad and remove program you can see the new window appear name current install files you can see the printer driver bellow click uninstall. to take effect restart you pc din install again the printer driver.
and chk your tuner or ink maybe if not empty thank you hope i can help you... have a good day!!!!!!
SOURCE: Can one reset the Lexmark P6250 printer refilled cartridge?
No, you can usually tell your printer to "ignore ink levels" when it gives the ink low warning on your computer screen. As long as they print just keep printing until they run out.
