Question about Maytag Refrigerators
Inside the box would be a door gasket issue maybe. Easy fix just silicone enough to fill problem area just a little bit thicker than needed at bedtime to the gasket, cover with plastic wrap, shut door. Cut away excess plastic after dry. If in pan under fridge make sure coil and fan are clean. Must have cardboard or metal across the back like factory designed to draw
or push warm air over the pan. Many back panels get damaged or completely gone.
Posted on Mar 25, 2019
Hi. this drain is in the panel of the refrigerator in the Botton.were the lights at ,, take this panel and you will find the drain
Testimonial: "This has 2 lights at the top front of the refrig compartment."
SOURCE: maytag side by side multi problems
1. Ice maker is not cold enough to start the ice making process.
3. having to take off the back panel is an indication of a problem in the defrost system. Call to have a service tech check this out.
Posted on May 31, 2008
SOURCE: Bottom of freezer has water dripping into it
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
SOURCE: Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Posted on Aug 23, 2009
Testimonial: "So far that worked great, we will see if it continues to drain when the freezer is back on and does it defrost cycle."
SOURCE: ice buildup in freezer drip pan and water overflow
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Posted on Sep 21, 2009
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Posted on Jan 04, 2010
May 04, 2012 | Maytag MTB2176HR Top Freezer Refrigerator
Jul 28, 2010 | Maytag MTB1976HR Top Freezer Refrigerator
Sep 23, 2009 | Jenn-Air JCD2389G Side by Side...
Aug 27, 2009 | Refrigerators
Jun 22, 2009 | Maytag MSD2456G Side by Side Refrigerator
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
Mar 27, 2009 | Refrigerators
Aug 05, 2008 | Refrigerators
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
82 people viewed this question
