French Doors
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
SOURCE: subzero 500 series ice maker
It sound's like you have a faulty icemaker. The icemaker has an internal timer that commands the inlet valve on at the correct time. If it does not stop the command, it will continue to fill. When you shut off the system, it kills power to the icemaker and that is why the solenoid goes off.
SOURCE: Ice maker panel came loose on LG LSC26905TT fridge
Please use the attched link to get the service and user manuals for your fridge. There are exploded views there as well so that should provide you suffiicient information to reinstall your panel. You can also get part numbers etc for replacements if that is necessary.. Hope this helps you...
http://136.166.4.200/contents/Fridge/LSC26905.htm
Regards,
Rick
SOURCE: GE side by side fridge. Ice maker makes ice, but
you need to atake the ice bin out and thaw all the ice in it out. its causing the auger to be in a bind
