Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Ice maker quit working
Turned off the bottom freezer ice maker on our Samsung RF266AEPN french door fridge for 12 days while we were on vacation and when we got back and turned it on... it wouldn't work. Tried the reset button. Nothing.
The owners manual does not provide troubleshooting and can find nothing online about it either.
This fridge is less than one month old!
Posted by bluemags794 on
dennis dodge
  • 1,891 Answers
Go back to your sales people this is under warranty and it's propably a system problem . don't void warranty . // hold on i thought the sysem had failed . ice maker must be 15 deg or lower . to work ... close the drawer and give it 24 and see what it will do . but it is still under mfg warranty . **** ..
Posted on Jan 06, 2010
Samsung french door fridge has clicking ice maker, what is wrong
The gear that turns the ice maker is Nylon and is most likely striped
You would be better off replaceing it with a New One, find it on ebay
Apr 28, 2014 | Samsung RF265AA Bottom Freezer French Door...
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Samsung RF266AEPN
Rfg298aars ice maker
My Samsung French door fridge #RF267abbp makes a knocking sound coming from the ice maker. The knocking lasts for about45 minutes and continues throughout the day and night, It is very annoying especially at 3 am.
Oct 02, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I have a Samsung refrigerator with a bottom freezer. The 'fridge and freezer temp settings are displayed on a panel between the upper and lower doors. The unit is about 4 years old. About a year ago,...
Hi adc3,
If the display has stopped working, it is often caused by a blown fuse. Please locate the main control board and check if there's a fuse that may have blown. For the ice maker issue, please check if the ice maker has been turned off. You can check it by looking for a wire that looks like a coat hanger that is located at the right side of the ice maker. Ensure that this wire is not in the raised position. If it is turned off, just simply lower the wire to the down position to turn on the ice maker. If this did not work, please check the tooth on the drive or driven gear of the ice maker. If you noticed a broken tooth you should replace the ice maker.
Hope it helps.
Thank you for using FixYa.
Jun 14, 2011 | Samsung RF265AA Bottom Freezer French Door...
Icemaker 3 drawer fridge
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
bmbmm,b
May 27, 2010 | Samsung RS2534 Side by Side Refrigerator
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
907 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
