Radio Communications Logo
M
Melo Posted on Jan 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I program different names for channels on my Motorola CP185 two way radio? To show up on the small screen in front?
Level 3:
  • Motorola Master 19,187 Answers
  • Posted on Feb 01, 2019
Motorola Master
Level 3:
Answers
19187
Questions
0
Helped
4346390
Points
82261
5 Related Answers
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Jun 26, 2008
SOURCE: change scanning feature for different channels
When having the radio programmed indicate to the programmer which channels you would like to have in a specific scan group. They an at that time set up a particular group for you.
eradiostore
eradiostore
  • 1672 Answers
  • Posted on May 30, 2009
SOURCE: How to program
The M1225 mobile is Motorola dealer programmable using the appropriate Motorola software, radio interface box (RIB) and programming cable. The cost for this type of programming is generally $15-$25.
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Jun 10, 2009
SOURCE: I have a Motorola SX600R two-way radio. Battery
Remove the battery and reinsert it to reset the radio. Also, check to see if any buttons are depressed or stuck. If these are not the cause, you might have a bad radio. (Sorry)
Anonymous
  • 123 Answers
  • Posted on Feb 04, 2010
SOURCE: Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Testimonial: "Thanks for the response. appreciated it. It is very useful."
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Oct 29, 2011
SOURCE: Can a Motorola CLS 1410 4 channel can be
Yes. Put the radio in programming mode and walk though the programming steps. The Privacy Tone is referred to as CODE in the manual. Here is a link to the manual http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf. Programming instructions begin on page 28.
Best regards.
What is error code 2629 and how to fix it?
Al Contact Motorola Solutions. Http://www.motorolasolutions.com/support.
Mark
Motorola Support
DECODING MODEL NUMBER/FREQUENCY RANGE
This is the model number for a UHF Motorola CP185. Specifically, 16-Channel, 4W Model 435-480 MHz. The only way to determine the frequencies programmed into the radio is to have the radio read-out by an authorized Motorola dealer or other entity with a subscription to the software, as well as, a radio interface box (RIB) and appropriate cable.
Best regards.
2answers
Motorola UHF CP185 Transmitter Frequency Error Adjustment
You can indeed adjust the frequency error on the CP185. You will need a very small (preferably ceramic, but you could get by with any) screwdriver. Use some alligator clips to power on the radio with the battery not attached to the back, and peel back the small circular metal sticker. Under it you will find a very sensitive potentiometer which you can adjust with your screwdriver, while transmitting, to fix the frequency error.
2answers
How do I know if my Motorola CP185 is UHF or VHF without taking it to a dealer for programming?
Hi christo,
Yes the serial No. usually indicates the frequency band the radio works on, but not always, because a lot of radios nowadays can operate on both VHF & UHF, so not being familiar with your model, I can't give you a definitive answer.
I do have the feeling, for what it's worth, that it is in fact a UHF band radio, but don't take that as gospel.
Anyone else reading this post is most welcome to assist in helping a friend out, we would much appreciate your input, thanks.
Hang in there my friend, there will be an answer soon.
Cheers, Peter
I'll look into it further as well....
How to enable all channels
The CP185 is dealer programmable for up to 16 channels. You would need to see an authorized Motorola dealer to have the radio reprogrammed to your additional FCC assigned frequencies.
Best regards.
CP185 radio won't stop beeping and is flashing red
Could be a variety of problems. Common issues might include a bad or poorly charged battery, an unprogrammed channel is selected, or you are programmed for busy channel lock out, and their is local traffic on your frequency causing you to be blocked out.
To test your battery, try trading with another radio which has a known good battery.
Check with your local dealer or a repair facility for more help.
Best regards.
Is the CP185 narrowband capable?
Yes. It is programmable to either wideband or narrowband on each channel. All current model VHF and UHF Motorola radios are narrowband capable.
Best regards.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
