Question about Motorola CP185 (16 Channels) Two Way Radio
What is error code 2629 and how to fix it?
When to open program to reporgram radio and got error 2629
Posted by Al Welsheimer on
Motorola Mobility
  • Official Brand Answer
  • 3,100 Answers
Al Contact Motorola Solutions. Http://www.motorolasolutions.com/support.
Mark
Motorola Support
Posted on Sep 03, 2014
What is Error code 2629
Helps to know what radio. They are not all the same.
Sep 03, 2014 | Radio Communications
(Error code: 0xE000003D) IN ONE NOTE
hey, you may follow the below steps:
Steps to Fix/Resolve/troubleshoot the error code 0xE000003D:
1 - Repair your Office app
Error Code 0xE000003D will be fixed when Office repair tool replaces all the corrupted system files. Follow the steps below to run repair tool to fix the error.
  1. Open Control Panel using Start.
  2. Click on Programs and select Programs and Features.
  3. Click on the Office product that you want to repair.
  4. Click Change.
  5. Select Quick Repair and click on Repair. If Quick Repair didn't fix the Error Code 0xE000003D, select Online Repair and click on Repair.
Note: If Office Repair did not fix this error code, then remove and reinstall the Office installation to fix this Error Code 0xE000003D.
2 - Steps to remove Office
In case if the error persists even after running Office repair tool, uninstall Office from your computer.
  1. Click on Programs and select Programs and Features.
  2. Select Office Suite and click on Remove.
Note: If Office installation failed or it didn't fix the error, a manual installation is required to completely remove the Office Suite.
3 - Steps to remove Office manually to fix the Error Code 0xE000003D
If the error code 0xE000003D is re-occurring, proceed with the following steps to manually remove Office program from your computer.
Step 1: Remove the Windows Installer packages
  1. Find the Office 16 installation folder, typically located in C:\Program Files\.
  2. Right-click the Microsoft Office 16 folder and select Delete.
Step 2: Remove the Office scheduled tasks
  1. Open a Command Prompt window as an administrator.
  2. At the command prompt, type the following commands and press Enter after each one:
schtasks.exe /delete /tn "\Microsoft\Office\Office Automatic Updates"
schtasks.exe /delete /tn "\Microsoft\Office\Office Subscription Maintenance"
schtasks.exe /delete /tn "\Microsoft\Office\Office Click To Run Service Monitor"
Step 3: Use Task Manager to end the Click-to-Run tasks
  1. Open Task Manager.
  2. Click the Process tab
  3. If the following processes are running, right-click each one, and then click End task after you select each process.
  • .exe
  • setup*.exe
Step 4: Delete the Office files
  1. Press Windows logo key + R to open the Run dialog box.
  2. In the Open box, type %ProgramFiles%, and then click OK.
  3. Delete the "Microsoft Office 16" folder.
  4. Delete the "Microsoft Office" folder.
  5. Open the Run dialog box, type %ProgramFiles(x86)%, and then click OK.
  6. Delete the "Microsoft Office" folder.
Step 5: Delete the Office registry sub keys
  1. Open Registry Editor.
  2. Delete the following registry sub keys:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\ClickToRun
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\AppVISV
  • HKEY_CURRENT_USER\Software\Microsoft\Office
  • Then Delete the Office key.
Step 6: Delete the Start menu shortcuts
  2. Type %ALLUSERSPROFILE%\Microsoft\Windows\Start Menu\Programs, and then press Enter.
  3. Delete the "Microsoft Office 2016 Tools" folder.
4 - Download and install Office
1. Sign in to your My Account page using the link https://go.microsoft.com/fwlink/p/?LinkId=613327
2. Choose Install.
3. Click Run or the equivalent depending on the browser you're using.
4. When you see "You're good to go", click All done.
Error Code 0xE000003D for Microsoft Office Outlook and Windows Updates
Dec 26, 2012 | Computers & Internet
My battery died for my 2007 honda civic and now the radio will not turn now.. it says error code.. how do i fix that ?
----- Error code radio Honda Civic 2007 -----
power on radio, when you see Error code 1 or 2 or 3 ..., power off the radio, press the keys 6 and 1 at the same time, and power on, you'll see the radio serial number, write down this S/N and call your dealer, give him this S/N, he will give you the code (5 numbers), that's it that's all
Lahoucine Dahir
Feb 27, 2011 | 2007 Honda Civic GX NGV Sedan
FI have a cb radio from Hong how do Ichange frequency to suit Australia. The radio is Qishi fm transceiver, QS-368S.Is it possible to change crystals,if they still use crystals
There are versions of this radio on different bands, some versions will not work on the Australian 477MHz CB channels even if reprogrammed.
Reporgramming the radio requires the software and a programming cable. Ask you radio supplier if the software and a cable is available.
If the radio is a version that will work and you manage to reprogram it it may work but will not be legal to use on the Australian UHF CB system because it is not type approved.
Sep 05, 2010 | Radio Communications
My remote is opening both my door and my neighbor's door. I think we accidently swithched them and once reporgrammed, mine opens both doors. How can I re-program it to open only my door?
one or the other remote has an error so when you set up your remote make sure neighbor is not home ... I had this problem when my neighbor was home and I reset my remote and keypad ... later I noticed my neighbors door either opened or closed with mine I called customer support and found the neighbors sensor emitted constantly and reset to mine. ... soo Reset you remote and keypad if you have one when you neighbor is away!!! :)
Sep 29, 2009 | Televison & Video
How do I set my motorola's VHF on the same channels? I have two of them and it use to be on the same channel but it accidentally got changed and now it don't work together anymore.
Need more information than you gave, like a model number of the radio.
If you have crystals that were moved around in different orders , you will need a tech to place them together in the same order and retune the radios, if your radios use a software program to create the channel frequencies and all its settings, then again you need a tech to reporgram your radios.
Jun 07, 2009 | Motorola TalkAbout P14SPC03P2AA 2-Way...
E3 error code on danby dhcc6020, its new out of box. tried danby service rep. , cant get a response back from them. any ideas on how to fix?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I had called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Danby Service Rep. helped me with my question about my P1 code (for DDR657EE).
Apr 11, 2009 | Danby DHCC6020 Dehumidifier
I can't install XP on Thinkpad A20P #2629
im sorry to say this laptop is just not fast enuf to run windows XP you best bet for this would be to run windows 98 or a distro of linux that fits your needs  there are no bios updates at this time that will allow you to install XP on this system. sorry
Mar 27, 2009 | IBM ThinkPad A20 2629 Notebook
Realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Jun 24, 2008 | Audio Players & Recorders
Danby ddr401 dehumidifier reading 'E5' error code on screen. Answer not in manual
have you tried phoning danby?
1-800-263-2629 customer support
Apr 28, 2008 | Heating & Cooling
Motorola CP185 (16 Channels) Two Way Radio Logo
70 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
