20 Most Recent Motorola Walkie Talkie 2-Way Radio Questions & Answers
Even the privacy codes are the same? Does the little light come on to tell you that it's receiving a signal?
Motorola Walkie... • Answered on Nov 18, 2017
Sometimes portable radios forget their encryption keys, especially when it takes you longer than 30 seconds to change a dead battery. You may have to either re-flash the key into the radio or else change the software setting from security hardware equipped to NOT security hardware equipped, or else just ignore the key fail warning and realize that your transmission is no longer encrypted like it used to be.
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
Motorola Walkie... • Answered on Sep 10, 2017
It sounds like your monitor button is stuck and you are hearing the white noise. Try pressing the monitor button on your other radio and see if the noise is the same. If so, your button is stuck. If not... Sometimes a lot of static can be an indication of a bad or poorly charged battery. To check for this trade batteries with your known good radio and see if it solves the problem.
Sorry,but no. The radio is non-repairable once the antenna has been removed.
Best regards.
Motorola Walkie... • Answered on Mar 30, 2016
Check your private line (PL) code in programming to see if all the radios match.
Motorola Walkie... • Answered on Feb 16, 2016
Parts are not available for this model. Your best options are to replace the unit or watch for a parts radio on ebay
Motorola Walkie... • Answered on Dec 17, 2015
2 miles line of sight as a general rule
http://shop.giantintl.com/Manuals.asp?offset=30
Look for the user guide here: http://shop.giantintl.com/Manuals.asp?offset=30
Check your battery, a sign of a low or bad battery is usually static.
Check your batteries. A sign of a low or bad battery is usually static.
PTT short circuit, remove the short
Motorola Walkie... • Answered on Jun 25, 2015
Your volume potentiometer is bad and needs replaced.
Motorola Walkie... • Answered on Mar 27, 2015
Contact Motorola Solutions Get Support Mark Motorola Support
Motorola Walkie... • Answered on Feb 11, 2015
Radio Communications Logo
351 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Sheldon Dedek
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
whats frequency range k7gfv300
  • Radio Communications
