20 Most Recent
Motorola Mint Radius Cp200 Uhf 4ch Radio Questions & Answers
Why motorola radius cp200 flashes red while charging?
Typically when the charger flashes red you have one of the following conditions:
1) The battery is simply too low to charge. Leave it on the charger for a few hours to see if it resolves. If it is a new battery return the battery for a replacement.
2) Your battery is not making good connection. Clean the battery and charger contacts with a pencil eraser. Check your contacts in the charge itself to make certain one isn't damaged or broken.
3) Your battery has an internal short. Test the battery on another charger to see if you get the same result. If so, replace the battery. 4) If you have a charger problem, the best test is to try another battery in the charger. Reminder: be certain the insert is turned the correct direction for the battery you are using.
Best regards.
ONE OF MY CP200 RADIOS HAS A STEADY SQUE
One possible problem is a bad battery. Try swapping batteries with a known good unit and see if the problem is solved. If it is not the battery, then your radio is likely in need of repair. Best regards.
Service center in bangalore
You could try taking out the batteries and putting it in rice for a couple of days and see if that helps.
I got one of my Motorola 2-way radios wet and after I dried it out everything seemed to work except the microphone; my suspicion is that the transducer needed to be replaced but I found that I could get used Motorola 2-way radios on eBay inexpensively enough that it made more sense to buy some of those than it did to try to repair the radio I got wet.
If you think you might be prone to dropping your two-radios in the water in the future, Motorola makes some two-way radios that are waterproof.
Motorola talkabout red light on radio stays on while charging
Your radio needs to be turned off when on the charger, and be certain you are using a rechargeable Motorola battery. The charger will not charge AAA batteries or rechargeable style AAA batteries. If the light does not illuminate on your charger, try the radio in a different charger and see if it does. This will tell you if it is the radio or the charger. One further note, you should clean your charge contacts with a pencil eraser to insure they are making good connection.
Program manual for motorola astro spectra w7 vhf
Astro Spectra radios are only programmable using Motorola proprietary software. (Subscription based from Motorola) They do not supply instructions other than what is within the help section of the software.
