S
Silas Eubanks Posted on Jan 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a missing cartridge but the cartridge assembly wont go to left so I can put the cartridge in
HP Officejet 8600 Plus. It just cycles on Preparing Printer... and never lets e put the cartridge back in Can I just power off and back on?
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Jan 20, 2019
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1814625
Points
14613
Yes just do it be ok
5 Related Answers
Anonymous
  • Posted on Aug 26, 2008
SOURCE: i have an hp officejet
I had this same problem and fixed it by doing a partial reset. Hold buttons 3 and # down and reinstall power.
Anonymous
  • 2120 Answers
  • Posted on Jan 31, 2009
SOURCE: ink level monitoring on officejet 6310
Yes. Never refill or buy refilled ink carts.
Anonymous
  • 22 Answers
  • Posted on Sep 07, 2009
SOURCE: HP Officejet printer, says cartridges are missing or not detected
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr11
Anonymous
  • Posted on Jan 17, 2011
SOURCE: my hp printer officejet k 8600 does not print from
hp pro k8600 does not print a3 scale
puertobori
  • 7733 Answers
  • Posted on Mar 04, 2011
SOURCE: My HP 8600 Officejet Pro
Try using the HP Print Diagnostic Utility in Windows..
If you need more help post back!
Thumbs and testimonial are welcome!
1helpful
I bought all new cartridges, inserted them the way they were removed, but message board still says defected cartridges. how to install ink properly and make error message disappear?
Here is a video from HP explaining the process. IF you followed this procedure and are getting errors, then you may have bigger issues. I am assuming you are using genuine HP ink, not remanufactured or refilled cartridges.
Replacing Cartridges for HP Officejet Pro 8600 All in One Printer Series...
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
How to disassemble
Power on printer and soak up spilled ink with towels. Next we suggest you remove PRINTHEAD from printer and inspect for damage to contact pin(s) on the INSIDE OF THE PRINTHEAD ASSEMBLY. Please refer to printhead removal procedure below for reference (HP Officejet PRO 8600 Printhead Removal & Replacement Procedure):
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c02871867
NOTE: To gain access to the service menus and advance printer reset procedures (and service tests) for the HP Officejet Pro 8600, 8610, 8620 or 8630 series printers please refer to our HP Diagnostics document at the following link:
Advanced HP Printer Diagnostics (i.e. printer self tests, etc.): http://inkjet411.com/?page_id=1813
Please note that if you choose to refill your ink cartridges with Costco/Frys, etc., the refill comes with a new chip so the ink level monitoring will be reset and function like a brand new HP OEM ink cartridge. We provide professional HP 950/951 ink cartridge refilling services in multiple countries and at multiple retail outlets:
INK REFILL SERVICES:
Costco USA (462 stores): http://www.costcoinkjetrefill.com
Costco Canada (57 stores, more coming soon): http://www.ca.costcoinkjetrefill.com
Costco Mexico (35 stores): http://es.costcoinkjetrefill.com/
Fry's Electronics (34 stores): http://www.frys.com/ads/page51
Best Buy Canada (13 stores): www.geeksquad.ca/inkrefill/
Micro Center (8 stores): http://www.microcenter.com/site/content/refill-service.aspx
9 Major Universities in USA & Canada
Ink Cartridge Refill Store Map Locator: http://www.go2ris.com/
Our network of retailers stand behind the product and performance - guaranteed. Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at [email protected]
Alternatively, if you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20.
-Thank you
Why does my non-oem cartridge reads as damaged on my HP Officejet Pro 8600?
you need to replace all colors with after market cartridges not just one
I installed HP officejet 8600 new printer cartridges, now "there is a problem with the printer or ink system. turn printer off then on. if problem persists, call HP"
Try this once: remove the cartridges you did place, check if all contacts are clean and place them back, one by one. Just a little piece of paper or plastic can spoil the fun. Also check the con acts in the printer if you can see them. (eventually use a slash light)
Make sure all cartridges are correctly placed and every lit and lock is closed correct.
Then start again.
If tis does not help, call HP.
Info how to remove an ink cartridge to replace it in HP Officejet Pro 8600
open front door from left side just pull outside and press and release the cratridge which is to be replaced it comes outside (acting like push to on button)
again push new one
Top The Office Equipment & Supplies Experts
vince
littlewheel
Jean Thiebaux
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
