20 Most Recent
HP Officejet Pro 8600 Plus e-All-in-One - multifunction fax / copier / printer / scanner color Questions & Answers
Paper size mismatch
1. Measure the paper you are using. A4 or Letter.
2. Set your printer driver default (on the computer) to the size in step 1
3. In each of the program like excel, word or adobe, remember to check page setup and make sure the size is that same as the paper size.
Replaced Cyan ink and now it will not recognize. Brand new cartidge
Did you use HP ink or generic? Generic inks will only be recognized if they have the chip that talks to the printer. That is not to say they won't work - you just will not know the level. If you did use HP you have to make sure you have removed the taped portions, and that it "clicked" when you put it in the cartridge. Also - double check you really put in Cyan, I have put in the wrong color in a slot and it will not recognize the cartridge - boy did I feel really silly that day!
Hp 8600 lines on scanning and copying
Hi
The link below, looks slightly odd, but takes you to a page on the HP website with several solutions to this problem and also lots of diagrams shoeing you how to implement their solutions -
EmptyPortlet
Hope this is helpful, if so would you please register that with Fixya
Cheers
How do I install a new ink cartridge in an 8600
Hi
Rather than give you a long screed about the cartridge replacement, if you go to this webpage, it is a manual for your printer in pdf format which you can save to your computer for future reference:
http://h10032.www1.hp.com/ctg/Manual/c03026243
The relevant page of the manual for changing cartridges is page 93 of the manual. This refers to the "ink cartridge access door". If it is not obvious where this on the printer when you look at it, then page 13 of the manual shows you where it is.
Cheers
Squeaking when it scans
If its scanning well and is out of warranty ignore it. If its under warranty get it replace. Quite often its not a problem, or just the high resolution stepper motor Operating.
