Question about The Office Equipment & Supplies
For some reason your computer isn't recognizing the printer. Try rebooting the printer and then the computer to see if they reconnect. If they don't then go thru the setup process for the printer again.
Posted on Apr 04, 2018
SOURCE: A communication error has occurred.
A.Unplug and re connect the printer B.Go to Printers and Faxes and click on install printer. When sked for CD or go to list- select - Go to List Select Make Select Model Click OK Make it your default printer
Posted on Jun 30, 2007
SOURCE: Lexmark X 1270 Can not Print
I may be a bit late with this but it worked for me. Uninstall your antivirus, remove any parental controls and disable your firewall. Then, reinstall the printer and download a 2008 version of your anti virus and re-enable your firewall. I haven't reactivated the parental controls just in case it all goes pear shaped.
Posted on Nov 06, 2008
SOURCE: error 306 is happening each time i try to print document.
I reloaded the printer driver and it worked again.
Posted on Mar 31, 2009
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
SOURCE: Communication Error when uploading photos
You may have switched USB mode to Pictbridge by mistake.
Press Menu/OK, select Setup, choose USB mode (on 3rd page) switch from Pictbridge to DSC, press OK.
Posted on Oct 13, 2009
