Try searching for WW2715 installation took lees than 10 seconds for answer.
http://www.how2install.it/manuals/complete_pdfs/85/1F/851F11F4A838812766D84B5B8DDA12B6C863A840.pdf
Testimonial: "thanks Steve, i tried looking but couldn't ever find the specs, only manuals. Your awesome, thank you Jon Davis"
SOURCE: jenn air double ovens
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
SOURCE: Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F1
Defective touch pad or membrane
Replace touch pad or membrane (this problem is usually the touch pad)
F1
Watchdog on board
Replace touch pad or clock assembly (also called the ERC)
F2
Oven too hot
Replace relay board (if present) or oven temperature sensor
F3 or F4
Open or shorted oven temperature sensor
Replace oven temperature sensor
F5
Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
F6
Missing AC signal
Check for proper voltage
F7
Function key shorted or stuck button
Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
F8
Analog/Digital supervisory
F9
Door latch supervisory
Check door lock circuit or replace clock assembly (also called the ERC)
F0
Function key stuck
SOURCE: Selfcleaning Jenn-Air electric oven
door lock switch must activate for clean to work. door may not be shut completely.
SOURCE: The upper oven has faulty code 4d22 every time i try to clean
I just tried the suggestion to cut the power to the oven from the box for 1 minutes, and it worked! I feel like I just earned a day's pay!
SOURCE: Our Jenn-Air double oven is 10 yrs old. Will not
There are 3 things that can cause this:
1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out.
Regards,
Bruce
www.fixyourboard.com
