20 Most Recent Jenn-Air JJW9830D Electric Double Oven Questions & Answers
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Jenn-Air... | Answered on Oct 24, 2014
I need to purchase light bulbs for Jenn-Air Electric Double Wall Oven model # JJW9830D
Jenn-Air... | Answered on Nov 16, 2010
This is a control board / unit problem with these models. It is not an easy repair really, but if you are extremely handy it can be done. Let me know if you want to try the repair yourself and I can find the part.
Thanks
Tim
Jenn-Air... | Answered on Oct 09, 2010
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jenn-Air... | Answered on Oct 03, 2010
You will need to adjust the door hinges so it pulls the door in tight enough.
Jenn-Air... | Answered on Feb 28, 2010
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by Briangem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF.
Jenn-Air... | Answered on Aug 12, 2009
Hi
If you have connected correctly and the ribbon cable is also fine then it seems that the touch pad is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jenn-Air Ovens | Answered on Apr 15, 2019
CALL A REPAIR SERVICE LOCALLY WE COULD NEVER GUESS AT WHAT WENT WRONG WHEN NOT BEING USED FOR YEARS CORROSION HAPPENS
Jenn-Air Ovens | Answered on Apr 13, 2019
FR Second oven error sensed
The unit never detected a sufficient rise in temperature in the second oven.
Jenn-Air Ovens | Answered on Jan 24, 2019
Jenn-Air JJW9830D Electric Double Oven Logo
13 questions posted
Top Jenn-Air Ovens Experts
Michael Thomas
Michael Thomas
Paul Bade
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Ovens
  • Jenn-Air Ovens
Most Popular Question
jenn air jjw9830ddp double oven
  • Ovens
