Watches Logo
C
Craig Posted on Dec 25, 2018
Wildgames terra 12 date, time load then I get err and nothingelse
2helpful
2answers
Why does the date on my seiko sne881 change at 12 noon?
probably because you have it set to 12 pm midnight and not 12 noon so at 12 noon it is actually midnight when the date will change
reset the time of the day to am or pm and any pm settings will change the date at 12 midnight.
My cat watch shockmaster s1143 is delayed by 12hrs. the date indicator didnt match for the current day today. pls help.
When you set the time and date, you set it to (example:) 12 noon rather than 12 midnight. Just turn your time back by 12 hours.
Date change
Hi.
I take it that your watch changes date at 12 noon, instead of 12 midnight.
If so change the time of your watch 12 hours, so it reads the same time, but instead of am, it is pm, or visa versa. Analog watches do not have a 24 hour time setting.
1helpful
Date does not change after 12:00 am
Does it change at all? You may just have to set the time 12 hours later so it changes at midnight not lunch time
2helpful
Don't know how to set the date except by winding the time dial repeatedly past 12 to get to present date--must be an easier way
I presume that you are winding the watch 24 hours to change the date.
You can shorten the time it takes to change the dates in the following manner:-
Wind the watch until the date changes, then turn it back until it passes 12 again and then turn it forward. Each time it passes 12 the date should increase by a day.
You may have to experiment to find how far past 12 in both directions to get the date to change.
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
3answers
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
1helpful
Set date
hello..this is not abig problem..just a sincronization one...ususlly I set the date around the 12 oclock in the night..the 0 hour..its easier...if you dont want to do this...well..then just count the hours ..remember you have the 24 hours /day..and remember the date is changing in the night around 12 oclock..
for instance...lets say..now you want to set the date..you count the hours until tonight at 12...you put it lets say...with 12 hours back..and wait the change in the midnight..
the easier way is to set it at midnight
oh...by the way..I saw watches which change the date around 2 oclock in the night..but this is a very small %...99% are set to do it at 12..
good luck
6helpful
3answers
Date changes wrong time
thats because analog watches don't know the difference between AM/PM. First reset the time, moving the hour and minute hands another 12 hours will let you know exactly what mode its in (am/pm) first allowing you to set the date correctly.
Nov 12, 2007 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
