Cell Phones Logo
V
Vivian Seale Posted on Nov 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i set up my voice mail with waya waya? they said dial 180, which i did, then enetered digit numbers, which does not accept?
Chan Sun
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 115 Answers
  • Posted on Nov 21, 2018
Chan Sun
Expert
Level 2:
Cheetah:
Answers
115
Questions
0
Helped
16582
Points
197
You need to contact waya as it is too hard to find info, try call 611 or operator on your mobile
5 Related Answers
Anonymous
  • 43 Answers
  • Posted on Feb 12, 2008
SOURCE: Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
Anonymous
  • Posted on Jul 29, 2008
SOURCE: RCA Model 25204 2 line speakerphone corded with call waiting caller ID
As bsmither said, how voice mail is accessed is very dependent on your phone company and how they've set things up. They would be the best place to ask about any problems you're having there.
As for programming the voice mail buttons on the 25204, I was confused by that one as well until I finally figured it out. Specializations aside, they're just speed dial buttons, and are programmed in exactly the same way as the ones along the right side of the phone. RCA could have documented that detail better than they did.
In my case, with Vonage, I just programmed the buttons with the numbers for the lines that they're associated with. When they dial and I'm connected to the voice mail system, I'm prompted for my VM password, which I then enter manually.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Sep 11, 2008
SOURCE: How do I undivert an extension?
Oh, the old forward to two destinatons trick :-)
If you're happy with the destination for C.O. Calls, you can set only the intercom call forward. There are *71xx codes that you dial. The 3rd digit is 0 for all calls, 1 for CO calls and 2 for itnercom calls.
The 4th digit can be 0/2/3/4/5 where zero is cancel, 2 is all, 3 is busy, 4 is no answer and 5 is busy/NA. The next digits are the destination which may also include an access code (9) and then #.
So, example to forward all intercom calls to voice mail (if 500) dial *7122 500 #. If the location for both calls is the same you can also reset everything by dialing *7100# then *7102 500 #.
Carl
Anonymous
  • Posted on Oct 03, 2008
SOURCE: voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Anonymous
  • 4 Answers
  • Posted on Nov 08, 2008
SOURCE: Wrong Voice Mail number programmed into Speed Dial "1" Key
You can not remove it; But you can change it
Follow the steps :-
>Menu
 >Messaging
   >Voice Messages
     >Voice Mailbox NO.(CHange it)
I need to set up my voice mail for conssumer cellular on my Iphone 4
Good Morning, Here are Step by Step Instructions on Setting Up Your Voicemail. Hope This Helps..
You must set up your mailbox the first time you use your U.S. Cellular Voice Mail. Please ensure you are using your wireless device for the initial set up.
  1. Access your mailbox by dialing *86 or your 10-digit wireless phone number + SEND
  2. Follow these prompts to set up your mailbox:
    1. Choose English or Spanish as your language preference
    2. Set up your 4-10 digit password
    3. Record your voice signature
    4. Record or select your greeting
  3. Start using your Mailbox Password
To protect your privacy, the new Voice Mail system doesn't allow "easy-to-guess" passwords, including repeating digits (3333), consecutive digits (1234 or 4321) or ascending or descending even/odd numbers (2468 or 7531). Your choice of a unique password will be an important step in protecting your Voice Mail service.
How do I set up my voice mail. now I have to dial my own phone # to get voice mail
Voice mail is usually obtained by dialing 123, but contact your cell phone service provider for the number if that doesn't work.
My Samsung phone never set viocemail pin
voice-mail is a phone number your phone dials that is managed by your carrier. if you dial voice-mail from you phone it usually doesn't require you enter a pin but if you dial your voice-mail from another phone you should have to. dial you voice-mail and follow the menu prompts if you want to change this.
Jun 24, 2014 • Cell Phones
To listern for voice mail,i have to entered the mail box number,i dont know my mail box number,how can i get the mailbox number in panasonic land line phones and model number is KX-TC1713
From your cell dial 1 by holding down till it dials your voice mail. If it has not been seet up previously it will ask you to do so. The default password is usually the last four digits of your cellular number. You can also dial your cell number from another phone such as a land line and let it ring till voice mail picks up. At that time press the ( * ) astrisk key to get mail. Very handy when your phone is dead etc...
Jun 30, 2011 • Cell Phones
Panasonic kx-t7453 corded digital super hybrid system How do I turn my voicemail box on so a caller can leave a message at my extension? thank you
Pretty much, it depends on what happens when you dial 165. That's the voice mail access number for a Panasonic TD phone system with Pana VM. If you get the voice mail lady, set the box up and then from the intercom dial 7102/3/4/5 where 2 is all/3 is busy, 4 is no answer and 5 is busy/no answer and 165 or whatever the VM access number is and possibly # (I forget if it's required). That will light the FWD/DND light and send calls to the voice mail system.
Carl
4helpful
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 • Cell Phones
How do I access my voice mail?
put your voice mail number in voice mail settings or you can dial directly your vc number to listen your voice mails,if you dont know your voice mail number then ask your network operator for number
Aug 29, 2010 • Cell Phones
1helpful
Setting up voicemail on sch-u340 phone..cannot read buttons on manual to set up..
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/more-carriers/SCH-U340ZBAUSC/index.idx?pagetype=prd_detail&tab=support
Setting Up Your Voice Mail from page 10 in your manual:
Voice mail allows callers to leave voice messages, which can be retrieved any time.
Note: Once your voice mail account has been set up, you can use the Voice Mail folder (under the Message menu) to view details of voice messages in your voice mail box.
1. In idle mode, press and hold the key or dial your own mobile number
to dial voice mail.
2. Follow the prompts in the new user tutorial to setup your mail box.
Listen to voice mail
to dial voice mail. After connecting, you will hear your voice greeting.
2. Interrupt your greeting by pressing .
3. You are then prompted to enter your password.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
2helpful
3answers
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
