SOURCE: can you give me any
At the onset, basic tools and equipment would include (but not be limited to):
A copy of the service manual or at least a schematic diagram with voltage readings would be very helpful. Repairs would involve sectoring the handheld into:
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: unable to program tk-3207
hi, all i can think of is- A, the computer is way too fast for the program you are trying to run, what you need is a really old slow computer or B,
check the COM port settings on your computer.
click start, right click on my computer, click properties, then click on the hardware tab, then device manager.
then there will be a 'Ports COM &LPT' just make sure the com port number is the same one as you are using on the software. Hope this helps.
SOURCE: AFTER I POWER OFF MY
It is likely your volume potentiometer has gone bad, and needs replaced. The best solution to shut the radio off and save your batteries is to remove the batteries when you are not using the unit, until you can get it repaired or replaced.
Do not use any spray cleaners in the volume potentiometer, as this can cause a harmful residue. If you try anything, consider canned air.
Best regards.
