Exercise & Fitness Logo
I had a fitbit account and lost my fitbit and deleted the app from my phone. i bought a versa and i can't load the app on my phone because my data belongs to another user, who is me. what do I do?
5 Related Answers
A
Anonymous
  • Posted on Sep 08, 2008
SOURCE: palm tx
Fixed - Hotsync all your stuff to your desktop. Remove any cards, and do a cold boot (press reset while holding down power button)
Then synch everything back again. I'm never buying another palm again.
Anonymous
  • 243 Answers
  • Posted on Sep 24, 2008
SOURCE: lost user account
You actually probably created the new account as an admin. You don't really need to recover it. You just use this account as your admin account. You can then create another non admin account now and have everyone else besides the "admin" likely being you, can use the non admin account. All your files can still be found in "rootdrive:\Documents and settings\administrator
There you can find all your documents that you had in My documents under the administrator account.
Hope this helps,
Midwest
Anonymous
  • 32 Answers
  • Posted on May 02, 2009
SOURCE: Erase Demo Games, Videos, and other ADS
go to lg-vu.net
Anonymous
  • 338 Answers
  • Posted on Sep 13, 2009
SOURCE: Accidentaly deleted my user account. Can i retrieve it back?
hi there,
reapplying the user won't help the case,
all you can do is:
you may have to find yourself a good unerase program(try pandora!) to find the deleted data, try to restore(they may be still in good shape, just try) all the files into one folder and then manually choose the data you want back.
A full restore of a once deleted user is almost impossibly, but remembering the actual programs and filenames you had saved on your harddisk may help a lot!
Good Luck.
cuda10358
Erik Boeselager
  • 63 Answers
  • Posted on Apr 26, 2012
SOURCE: How do you bring a deleted app back
Im afraid it's not possible. After you delete an app, everything goes with it. It remembers your username because of online registries for the app but nothing else. The data you want is stored on your ipod touch. The only way you could've saved it is if you backed up your ipod touch with itunes before you deleted it. Backing up in itunes saves all "in-app" data as well has what is on the ipod touch itself.....Sorry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
I just received a Fitbit Inspire - Do I have to have a Cell phone to use it? Is there a manual to use it?
No, you do not necessarily need a cell phone to use a Fitbit Inspire. While syncing the Fitbit with a smartphone can enhance its functionality by allowing you to receive notifications and track your data more comprehensively, you can still use the Fitbit Inspire without a smartphone.
To set up and use your Fitbit Inspire, you can follow these general steps:
  1. Charge your Fitbit: Plug your charging cable into a USB port or wall adapter and connect it to the charging port on the back of your Fitbit Inspire. Charge it fully before you start using it.
  2. Create a Fitbit account: If you don't have one, you will need to create a Fitbit account. You can do this on the Fitbit website or through the Fitbit app on a smartphone or tablet.
  3. Set up your Fitbit: Follow the on-screen instructions on your Fitbit device or the Fitbit app to set up your device. This typically involves connecting your Fitbit to your Fitbit account.
  4. Wear your Fitbit: Put on your Fitbit Inspire and start tracking your activity, sleep, and other metrics.
  5. Sync with your phone or computer (optional): If you have a smartphone or a computer with Bluetooth capabilities, you can sync your Fitbit data with the Fitbit app or Fitbit website to see your stats, set goals, and track your progress more comprehensively.
Jun 20, 2019 • Cell Phones
I just bought a Fitbit Versa I tried to register using my email addresst was already registered to another fitbit. That was the fitbit I bought several years ago How do I register this fitbit?
Remove the old Fitbit from the account
Fitbit app
Tap Your data in Fitbit. Scroll down, and tap Delete Fitbit from your Google Account. Log in to your Google Account. Under Delete a Google service, tap Fitbit and follow the on-screen instructions.
How do I delete my Fitbit account and service? - Google Help
Google Help
https://support.google.com > fitbit > answer
Remove old device for new one
Fitbit Community
https://community.fitbit.com > Android-App > td-p
Jan 19, 2021 - Hi @Bonnied07 sync and then remove the device from your account. click for directions. You'll want to move that old device out of range of ...
How do I remove Charge 2 from Fitbit account?
Fitbit Community
https://community.fitbit.com > td-p
About your old Charge 2, you can remove it by following these steps: Open the Fitbit app and tap your profile picture. Tap Charge 2 image: For iOS devices .
I bought a Fitbit versa special edition watch last week. It does not get any notifications from my Samsung note 9 phone. What do I do ? I live in Sydney, Australia
Did you enable notifications inside the app? this is the only way to get apps to work..permission from which app gives notification. Like messages. If you have a problem start over go to setting find that app then clear cache and data will put the app back..just start over. I use to have Fitbit i had sync problems I returned it. Maybe they fixed it since I owned.
2answers
How does fitbit work?
you wear it on your wrist after you charge it up via the usb charger.
You download fitbit app on your phone and then add fit bit to phone .
I am not sure how it works I am guessing it has a motion detector in it and each step causes a vibration it detects.
It must have some sort of a pulse sensor as it also knows when you are a sleep .
you need to set up an account using an email address with fitbit via the app.
there is also a windows app but you need the fit bit dongle that comes in the box it came with plugged into the usb port of p.c.
even thoug pc has bluetooth it does not seem to work with the p.c application unless the dongle is used with it.
2answers
How do I delete my info form the FitBit flex? I want to return my new flex to buy a FitBit Surge.
HOW DO I DELETE PROFILE DATA FROM MY TRACKER? Fitbit uses your height, weight, and age measurements to properly calculate your stride length (which helps determine your distance), calorie burn, and active minutes.
To delete your profile measurements from your tracker, the tracker must be set up to a different account. Once a tracker is set up to a different account, it will automatically unlink itself from the dashboard and all of the tracker's stored data will be permanently deleted from the tracker. You can find instructions on how to create a new account in the following articles:
How can i delete my samsung account from my mobile its a samsung galaxy young duos gt-s6102 my account id is [email protected]
Many useful and funny apps come up in Google Market everyday.We enjoying these advance procedures, at the mean time we find that the RAM of our Android phones are limited. So we have to delete some apps to release more RAM. In my opinion, it's very time consuming to delete and install apps one by one . So I choose a professional Android app organizer for my Samsung Galaxy S4 which can help me to organize apps directly on Windows(Mac supported).
With this Android app organizer-
MobileGo for Android, You can save your precious time to do more important things. Installing, uninstalling, exporting apps become so easily and quickly when you have MobileGo for Android.
Jul 29, 2013 • Cell Phones
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
