20 Most Recent
NRS Pfs Smoothflow R80 Rower Questions & Answers
Hi we have had the
Hi my name is Ray. I have a few question. 1.Was the unit brand new when you purchased it or used (Ebay sells alot of them) 2. the weight limit for the device is 250lb. (my dad broke his the same way) 3. Did the coil snap or just sprung? thank you for your patients Ray
8/5/2009 4:07:56 PM •
NRS Pfs...
Answered
on Aug 05, 2009
When I turned on my pro form 540s treadmill using the magnetic key it turned on like normal,
The issue with your ProForm 540s treadmill is likely due to a problem with the speed control circuit. Here are a few steps you can try to resolve the issue:
- Check the speed sensor: The speed sensor on the treadmill can be damaged, causing the control board to shut down the machine. Check the wiring and connections to the sensor, and replace it if it's damaged.
- Check the wiring: If the wiring connecting the control board and motor is damaged, it can cause the control board to shut down the machine. Check the wiring and connections for any damage, and repair or replace as necessary.
- Check the control board: If the control board is damaged, it can cause the machine to shut down. You can try to reset the control board by unplugging the machine from the electrical outlet for a few minutes and then plugging it back in. If the issue persists, you may need to replace the control board.
If you're not comfortable with the above steps, it's best to contact a qualified repair technician for assistance.
Is an E8 error on Ancheer treadmill fixable?
Whether an E8 error on an Ancheer treadmill can be fixed depends on its underlying cause. Possible causes like a broken control board, loose wires, or a damaged motor can sometimes be resolved with proper repair or component replacement. It's best to seek assistance from the manufacturer or a professional repair technician for proper diagnosis and resolution.
E8 Error Code on my Murtisol treadmill after 10 minutes. Can this be fixed?
An 'overweight' situation, often stated in error. Try lubricating the belt. I found this;
What does E8 mean on a treadmill?
Overload Condition
Answer: I had an E8 error on my Ancheer treadmill last year. It means an overload condition. At the time I was at least 60 pounds under the stated weight limit.
