Question about Cannon Office Equipment & Supplies
SOURCE: HOW TO LOAD MY 1600 CANNON PIXMA PRINTER
http://www.driverfiles.net/Printers/Canon/PIXMA-iP1600/download/page,sh,39298,430,12,.html might help
Posted on Mar 04, 2008
SOURCE: Installer cannon pixma ip 3000
You can download the said installer through this links:
http://software.canon-europe.com/products/0010094.asp
Posted on Sep 28, 2008
SOURCE: cannon pixma mp145 printer error code e7 & e2
E2: Reload the paper correctly and press [Black] or [Color].
E7: The cartridges are not installed in place.
These are from the manual.
Posted on May 10, 2010
SOURCE: Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Posted on May 16, 2010
If you have a wireless router with a wireless network then - Configure the IP address your wireless
printer, (this is done through the printer's menu settings) make sure it
matches the IP address range on your wireless network, it maybe 192.168.1.***
then configure the wireless printer with a fixed IP address with the same IP
address range but at a higher address eg. 192.168.1.10 so it does not clash
with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click
Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably
incorrect.
Posted on Oct 29, 2012
