Cannot connect IPad to cannon printer scanner
SOURCE: Cannon PIXMA MP520 Problem: Error code
I had this problem with the ink carriage jammed at the left hand side of the printer. I operated the lever in a hole on the top left hand side and eased the carriage along to the middle and pushed it back onto it's runners. All OK now.
SOURCE: Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
SOURCE: cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
SOURCE: error code U163 on cannon pixma mp220 printer
Those cartridges don't refill unless you have a way to reset the internal chip. Check online for refillable cartridges or a chip resetter. For priming you go into printer properties and choose maintenance and head cleaning, or choose cleaning from the front panel.
SOURCE: My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
