It works just fine on other computers, is fairly new, and hasn't been manhandled in a bad way recently. When I plug it in to either of the 2 usbs on this computer it doesn't do anything. No error, or unrecognized message at all. I tried looking through the settings to see if something was off, but nothing out of the ordinary popped out to me. Troubleshooting?
SOURCE: serial to usb wacom tablet problem
I just got Vista and it killed my Intuos2 w/serial to usb also, but here's a half solution:
Download Wacom driver 4.78-6 http://www.wacom-europe.com/int/downloads/driver/driver.asp?lang=en. Make sure you remove any other Wacom drivers, tablet, and reboot. Install 4.78-6 driver and select serial port when the choice pops up. Plug in your tablet with the serial to usb adapter, wait a few seconds and click retry. Complete the install and reboot.
Your Wacom tracking should work now, but certain things might not work like pressure sensitivity and you'll get annoying error "reinstall driver" pop-ups.
I think you can aslo buy a PCI-serial card for your computer and skip the serial-usb adapter since Vista doesn't support the adapter for Wacom tablets.. but I'm not sure if there's a working Vista serial Wacom driver either.. or ever will be. The age of XP and Legacy support is at an end my friends.
Searched for ages to find a driver for my giant wacom (UD-1212-R) on Vista 64. As of this moment there isn't one, and it looks like they are not even going to bother. But if there are any geniuses out there........
SOURCE: Unrecognized external HDD
This message usually indicates one of two things:
1 - The driver for the device is not loaded or has become corrupted (I trust that one of the other troubleshooting steps you took included reinstalling the drivers...) or more likely,
2 - The device has malfunctioned. More likely than not, the hard drive itself is OK, only the electronics in the case has failed.
If the device is still under warranty, give Maxtor Customer Service a call and get it replaced. Of course all of the data you have will be gone unless you can convince them to send you ONLY the replacement case and electronics, not the hard drive. In which case you will have to open the old case, remove the hard drive and put it into the new case.
SOURCE: USB cord (for Olympus Stylus 790) not recognized on computer
Hello :
The problem is not with the cord . But it's with the computer .
I'll give a solution assuming that you are using [ Windows XP ] as an Operating system . This can also go with [ Win 7 or Win Vista ] .
1: Go to start
2: Go to all programs
3: Go to accessories .
4: Go to system tools .
5: Click on [ restore ]
Now you will see many restoring points . Try to remember which point or time the ( Olympus Stylus ) was working fine .
6: You need to restore your system to that point or time .
7: The system will restore itself to the point you chose and will reboot .
8:After rebooting plug in your Camera USB cable to try if that worked or not . It should work . If not , then the problem is with the Camera . For that you need to reset the Camera and try again .
If that didn't help , then there must be a hardware failure with the camera and it needs to be serviced .
Please don't forget to rate !
good luck .
SOURCE: Wacom Intuos 3 problems
Hi Bengref
Just talked to WACOM USA about a similar (but not exactly the same) problem with my Intuos 3. One of their procedures was;
go to the ALL Programs directory,
go to the the WACOM TABLET directory
open the WACOM Tablet Properties window
click on the "About" button
while holding down the CTRL key, click on the "Diagnose" button
click on the "recalibrate" button
Another procedure
go to the All Programs Directory
go to the WACOM Tablet Directory
click on the :WACOM Table Preference File Utility"
Under "My Preferences" click on remove
Good Luck
BobS
