20 Most Recent Wacom (EP130EPE) Digital Pen Questions & Answers
2answers
Intuous pen "sticking"
Take out the "nib" and whack it on your desk (or drop it on the floor from 3 feet up). It re-seats the "nib" sensor when it's stuck. If this doesn't work, then the sensor may be too damaged.
11/27/2020 2:09:17 PM • Wacom (EP130EPE)... • Answered on Nov 27, 2020
2answers
How do you change the pen tip on a bamboo pen?
I posted this solution for a Toshiba Tablet PC that uses a Wacom tablet pen. I am rather confident that it will give you ideas on how to solve your problem.
With the stylus replacement tips there is an extraction tool: It looks like a wide ring split lengthwise.
You take the tool between thumb and index ( as you do a tweezer) and extract the worn out tip. Toshiba warns against letting the tip wear out too much: this renders extraction difficult.
Once you have extracted the worn out tip, insert a new one with the thinner side towards the outside. Press gently but firmly to make sure it is holding.
6/3/2014 5:01:28 PM • Wacom (EP130EPE)... • Answered on Jun 03, 2014
2answers
My Wacom intuos 4 pen is not working - the cursor
I had the same problem. I had to make sure that the tablet is the only thing plugged into the usb ports of the compiter and restart it. At the time when it wasnt working, my iphone was plugged in. Once i unplugged it an restarted my laptop, it worked
3/7/2014 3:10:30 AM • Wacom (EP130EPE)... • Answered on Mar 07, 2014
Wacom pen does not function
Unfortunately I had the same problem.
Its from moisture in the pen, could be from humidity or something spilling on it. Try searching google for information on how to fix wet electronics. (Im quite sure youre not supposed to use heat)
11/22/2013 6:33:23 AM • Wacom (EP130EPE)... • Answered on Nov 22, 2013
0answers
My Wacom Bamboo Pen only
Go to the Control Panel, click on the Hardware and Sound link, click on the Bamboo link. Make sure you are on the "Pen" tab. Look on the bottom right for the "Tracking" section. Make sure the "Pen Mode" is selected. Click on the "Details" button, make sure "Portions" is not selected in any of the sections.
If you can't fix it in this section, then your best bet is to re-install.
5/3/2011 3:20:20 PM • Wacom (EP130EPE)... • Answered on May 03, 2011
My digital pen for my pen tablet(bamboo/wacom)
Try hitting the head of your pen into the palm of your hand 5 times and do the same with the eraser. Something about the humidity making the pressure thing in the pen stick idk. I had the same problem and this worked for me.
1/29/2011 11:45:02 AM • Wacom (EP130EPE)... • Answered on Jan 29, 2011
I just got a Wacom Bamboo fun tablet. Having
It's a driver clash issue apparently, this is a common problem, seems OK in XP, and bad, in anything else, seems to be either a driver issues, or some other software alters setting after it is installed, some people have had success by reinstalling as another User, and have ONLY that program running and nothing else that maybe working in background, also has something to do with USB 2 and settings too. try the very latest software and un-install completely your last copy.
5/5/2010 11:20:59 AM • Wacom (EP130EPE)... • Answered on May 05, 2010
Tablet Pen moves very slowly across the screen.
This may be a processor issue, as mine does this too.
As for others, most issues surrounding the stylus are battery related.
I will help anybody with a broken, or inoperative stylus/pen get their pen operating again. I have started a business around this issue because so many people's pens are malfunctioning (including mine originally which drove me to do this). This was fueled by Gateway's lack of caring around the issue, and their attempts to charge ridiculous fees for customer service. I charge $20 to switch out the battery to get your stylus working again, plus shipping and handling both ways, about $25 total.
Email me at: kevin teman AT hotmail DOT com
Or,
See my website at:
[url=http://www.kevinteman.com/stylusrepair]Stylus Repair and Battery Replacement[/url]
Thank you, Kevin Teman kevinteman.com/stylusrepair
3/19/2010 1:33:34 AM • Wacom (EP130EPE)... • Answered on Mar 19, 2010
2answers
Pen keeps drawing when I lift it off tablet
This problem commonly occurs due to a stuck "nib" sensor (the sensor that detects pen pressure).
Take out the "nib" (important, so the sensor isn't damaged further) and whack the pen on your desk (or drop it on the floor from 3 feet up). It re-seats the "nib" sensor when it's stuck. If this doesn't work after multiple attempts, then the sensor may be too damaged.
1/19/2010 4:23:04 PM • Wacom (EP130EPE)... • Answered on Jan 19, 2010
2answers
Pen sticking
In settings, turn Tip Feel all the way to maximum Firm.
Does this help?
1/19/2010 4:16:55 PM • Wacom (EP130EPE)... • Answered on Jan 19, 2010
The pen is active but the clic doesn't work, the
there is a switch inside, but since it's on the same board, you'll still need to replace it.
12/11/2009 2:46:12 PM • Wacom (EP130EPE)... • Answered on Dec 11, 2009
4answers
Broken Wacom Bamboo Fun Pen
http://wishidknownthat.blogspot.com/2009/04/fixing-wacom-bamboo-pen.html
^ I believe this is exactly what you need to know. :3
9/17/2009 9:47:21 PM • Wacom (EP130EPE)... • Answered on Sep 17, 2009
I dropped my wacom tablet pen and now only the eraser is working!
...and it landed right on the tip, breaking the sensor, which could probably be tracked down and replaced.
... it landed on its side and has a mechanical malfunction which can be fixed by opening it and using careful observation and Yankee Engineering!
...or saving time, effort, and probably money, getting ahold of Wacom about a new one (BUT where's the FUN in THAT?)
GL!
8/24/2009 5:47:09 AM • Wacom (EP130EPE)... • Answered on Aug 24, 2009
Hello, My pen doesn't seem to work after the
try updating the drivers for the pen. though there are lot of issues regarding devices not waking up after standby in windows
8/8/2009 10:34:09 AM • Wacom (EP130EPE)... • Answered on Aug 08, 2009
Wacom (EP130EPE) Digital Pen Logo
38 questions posted
Top Wacom Computers & Internet Experts
Ekse
k24674
 Grubhead
Grubhead
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Wacom Computers & Internet
Most Popular Question
digital pen pen tablet bamboo wacom
  • Computers & Internet
