Update if ps3 and it cancelled half way thru. Now it won't reset or reboot is only stuck in update and reboot error code. Half way thru install it just resets and starts again
Https://www.youtube.com/watch?v=a5OIZ73U7v0
video states you have to format the usb memory stick to fat32
right click on drive for usb memory stick and select format and change file system to fat32.
Video also shows replacing hard drive this would be a extreme case and you would loose all your settings ,games downloaded , ect
SOURCE: ps3 not working
Is there sound? If so, then maybe your video settings got mixed up. Try the video reset.
When the PS3 is in standby mode (red LED lit), hold the Power "button" until it beeps for booting, keep holding until it beeps again (not to turn it off).
If done correctly you should see something again (480p resolution) allowing you to change settings.
I hope this will help you out.
Greetings,
DarkNeogen.
SOURCE: PS3 blackscreen, but sound! tried all common tricks to reset!
try getting a freid or someone you know to go through with you to try and change resolution of screen. i did this to help someone. doesnt work well but worth a try
SOURCE: Ps3 System Update Failed, PS3 boots with error code 8002F14E.
-Open the side of your PS3 where your HDD is. Take the screw out, but leave the HDD in.
-When the
update begins, pull your HDD out of the slot. It will tell you an
error occured and it tells you to restart your system and try again.
Instead, let the count from 60 run out, your screen will go blank for
about 30 seconds then it will start back up and tell you that your
Hard Drive needs to be reformatted. If you do not get this msg after 30 seconds, do it again until it does! Now, slide your HDD into place
again - (make sure your controller is PLUGGED IN) and press the white PS3 button on the controller. It will then ask you to either press start and select at same time OR white PS3 Button - PRESS START and SELECT. Do not agree to user agreements!! Simply hit cancel and it will kick back to the PS3 start up screen.
SOURCE: my ps3 is trying to install the new update of 2.80
As long as it is still in the downloading stage and not the installing stage then you can safely power down your PS3. Sometimes this happens if the server you are trying to download from is having issues... your best bet is to try again later.
SOURCE: carried out an update, but now stuck in loop
Procedure for Entering Safe mode when PS3 is caught in
update loop:
When you first turn on the PS3, it will not allow you to go
into Safe mode. You must prepare it for
this.
link for flash drive prep:
http://www.us.playstation.com/Support/SystemUpdates/PS3/pc_update.html#update_PC
(This will not work for the drive that currently is caught
in the update loop. You must take the
hard drive out of the PS3 and temporarily replace it with another 2.5” SATA
drive. Note: temp drive may need to be initialized…
Connect drive to pc, right click on My Computer and select Manage… Then select
disk Management… you will then be presented with a dialogue box that will
assist in initializing the disk.. However, only initialize it… Do Not Format
it!(waste of time) Once the disk is
initialized disconnect it from external enclosure or shut down computer and
remove disk)
From the top:
1.)
Plug in PS3 and flip switch in back of PS3 to on. Red LED in front of PS3 should light up. Also, plug in Controller at
this point.
2.)
Hold finger to I/O button on front of PS3 – Green LED
lights up
a. You
will hear one beep, then another single beep, then a final beep and the PS3
will power off again and Red LED will be on
3.)
lights up
a. You
will hear one beep, then another single beep, then two beeps
4.)
As soon as you hear the two beeps, hold PS button on
Controller
a. You
will then be presented with an options screen
i.
Restart System
-- leads back to update loop
ii.
Restore Default Settings --
iii.
Restore File System
(8002F14E)
iv.
Rebuild Database
v.
Restore PS3 System
vi.
System Update
-- will cause error
5.)
You will then remove the temporary SATA drive from the
PS3 and replace it with the hard drive that is caught in the update loo
6.) I am currently stuck attempting to Restore Default Settings and Im sure it will end in error, but i have to try all possible solutions.
