So let's get this out of the way, my computer is VERY old. Almost more than 10 years old, a Windows 7 I think. I don't think this is the cause of my tablet not working, because it has worked on this computer in the past. But now, whenever I try to plug in my drawing tablet it keeps flashing the top light on and off, and whenever I try to go to Wacom Tablet Properties, it says "Your device is not plugged into your computer" and things like that. This tablet still works on my laptop, but my computer has more space. Any suggestions of what I could do?
SOURCE: Tablet Pen isn't working...
try difrent usb ports, uninstall the drivers, reinstall the drivers.
well try that for start.
SOURCE: serial to usb wacom tablet problem
I just got Vista and it killed my Intuos2 w/serial to usb also, but here's a half solution:
Download Wacom driver 4.78-6 http://www.wacom-europe.com/int/downloads/driver/driver.asp?lang=en. Make sure you remove any other Wacom drivers, tablet, and reboot. Install 4.78-6 driver and select serial port when the choice pops up. Plug in your tablet with the serial to usb adapter, wait a few seconds and click retry. Complete the install and reboot.
Your Wacom tracking should work now, but certain things might not work like pressure sensitivity and you'll get annoying error "reinstall driver" pop-ups.
I think you can aslo buy a PCI-serial card for your computer and skip the serial-usb adapter since Vista doesn't support the adapter for Wacom tablets.. but I'm not sure if there's a working Vista serial Wacom driver either.. or ever will be. The age of XP and Legacy support is at an end my friends.
SOURCE: keeping wacom intuos plugged in
There shouldn't be a problem with keeping it always plugged in.
SOURCE: My computer suddenly won't recognize
Make sure driver is installed and there is not any ? mark or yellow ! mark in device manager.
Reinstall your tablet driver then check.
Uninstall all usb driver from computer.
Connect your tablet to computer then when you power up the computer press F8 key then enter in safe mode.
Make sure usb cable is works fine if you connect your tablet to computer with usb cable.
Let me know if you need further assistance.
Thanks for using FixYa.
SOURCE: I have an Intuos 3 Wacom tablet and I'm having
Try plugging into a rear usb port as front usb ports are not "powered".
