Ipod shuffle will flash green and orange light when I try to press play, and when I go to itunes, it reads that the ipod is corrupted and needs to be restored. Once there and tries to restore, it says cannot be restored error 1442
This 2008 FIXYA archive MAY help you!
APPLE IPOD SHUFFLE UNKNOWN ERROR 1442
I know it says SHUFFLE, but the FIX may be the same!
Anthony
SOURCE: APPLE IPOD SHUFFLE UNKNOWN ERROR 1442
I found a way to solve this, you have to google for a program called ipod reset utility or, you can search here:
http://support.apple.com/kb/HT1238
Either way, install, follow the instrucions and you can probably save your ipod (note; I saved my ipod on a mac. Haven't tested transfering songs from my PC an this moment)
SOURCE: ipod shuffle wont play music
Hi! Check out the link below, it has all the info-
http://support.apple.com/kb/HT1814?viewlocale=en_US
& also
http://discussions.apple.com/thread.jspa?messageID=1518896#1518896
Thanks
Rylee
SOURCE: 1st series ipod shuffle...working fine did latest
Here's simple steps to cure the problem if your iPod shuffle won't play
and does that green-yellow-green-yellow-green-yellow blinking thing:
If that doesn't work try the link below. It's for the iPod Shuffle (1st generation) restore utility.
Hope it helps.
SOURCE: ipod shuffle error:1442;Cannot restore or update
You can try resetting your ipod to the manufacturing defaults. The reset button looks like a small pin hole. When you locate the reset button press it with a paper clip or some thing of that size. Hold the reset button down for about 10 seconds. If this dose not correct the issue try reformatting the ipods hard drive. For more information check out the following URL.
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
I hope that information above has helped is some way.
If possible please rate this solution.
SOURCE: I have an ipod shuffle (2005) 512mb. It has never
If
your getting the 1442 error code wile trying to restore your ipod than
you may need to reinstall itunes. The following URL will bring you to
Apples ipod shuffle trouble shooting assistant. This site will provide you with a more descriptive trouble shooting process.
http://www.apple.com/support/ipod/five_rs/shuffle3gen/#
If your using the 1st or 2nd generation of the shuffle you can try the ipod reset utility located at the following web address.
