Apple iPod shuffle MP3 Player Logo
Posted on Oct 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1st series ipod shuffle...working fine did latest install from itunes and now ipod will sync but won't play...does repeating of green and orange lights. Tried the restore and resetting but still not working. Any other types?
david mcclellan
Level 3:
  • Master 530 Answers
  • Posted on Oct 24, 2009
david mcclellan
Master
Level 3:
Answers
530
Questions
0
Helped
303161
Points
1839
Here's simple steps to cure the problem if your iPod shuffle won't play and does that green-yellow-green-yellow-green-yellow blinking thing:
  1. Plug in iPod shuffle
  2. You'll notice the "Podcasts" play list under your iPod volume.
  3. Delete the "Podcasts" playlist.
  4. ITunes will re-sync
  5. Unmount the iPod Shuffle and everything should be fine.
If that doesn't work try the link below. It's for the iPod Shuffle (1st generation) restore utility.
Hope it helps.
http://support.apple.com/kb/HT1238
1helpful
When I turn on my ipod shuffle & hit play it blinks green and orange several times and won't play
The Apple iPod shuffle is a digital music player that contains a single indicator light that relays information about the device's battery condition, computer connection and any errors the device is having. The indicator light is capable of blinking red, green or orange as well as displaying a steady red, green or orange light. The iPod Shuffle includes a Universal Serial Bus interface and buttons on the front of the device for controlling music files.
Blinking Orange A blinking orange light indicates the iPod Shuffle is receiving an update via iTunes to the device's internal components. The update could include a patch to repair an error the player encountered once before, an update to the player's file-saving software, or a combination of security, repair and software updates. Updates are free and automatically sent directly from Apple through iTunes to your iPod shuffle before a sync process starts. Disconnecting iPod Shuffle When the player's light is blinking orange, do not unplug the device from your computer's USB port this will stop the update process and possible corrupt the device's internal hard drive. Let the update process and sync process finish before clicking "Eject" within iTunes and removing the player. Disk Use Enabled If you use your iPod Shuffle as a flash drive and not as a music player, a blinking orange light means that the device is connected to your computer and ready to accept files. The "Disk Use" enabled setting is changeable within iTunes if you decide to use your iPod Shuffle for music storage instead of file storage. When set up as a flash drive, the iPod Shuffle is assigned a drive letter by your computer's operating system and the drive lets you "drag and drop" files to the device. b> Charging If your iPod shuffle's battery is completely depleted or low on charge, connect the player to your computer immediately for charging then leave it connected to receive any updates to the device's software and internal components. Its indicator light may or may not blink orange until after it is fully charged. If the battery is low on charge or completely depleted, you may receive an error stating that the iPod is corrupt or needs restoring, close the error message and let the device fully charge.
b>
1helpful
It wont charge it blinks three times then stops
Hi,Okay, well, I don't want to be a shill for Apple (I mean, heck, I had to buy my Shuffle, so it's not like they're sponsoring this in any way! :-) so let's talk about the color sequences and what they mean.
First off, there are a number of different functions that are denoted by different color sequences, so flashing green might mean one thing when you're listening to music, and something else entirely when it's plugged in and charging or syncing with your PC.
The primary functions are powering on, charging, syncing, and general feedback. Let's look at each.
When you turn on your ipod shuffle, the light will indicate your current charge level:
green = 30-100% charge, you're good to cruise
orange = 10-30% charge, low, but still good for a short workout
red = less than 10% charge, time to plug it in
no light = too late, you've run out of juice
If you see an alternating pattern of green-orange-orange then your Shuffle's crashed or otherwise needs to be restored. Needless to say, that's not a good thing, but probably easy to fix when you hook it up to your PC or Mac.
When you're charging up your shuffle, there are three possible light states:
orange = charging
green = fully charged, unplug whenever you're ready to go
flashing orange = busy, either syncing or in use as a remote disk
When you're playing some music, you can see visual feedback on what's happening and what state you're in:
Press play and
solid green = you're playing music
flashing green = you're in pause mode
Press and hold play and
green-orange-orange-orange = you've disabled your buttons
orange-green-green-green = you've reenabled your buttons
That's bound to be one where people panic and fear that they've broken their shuffles, I bet. If your buttons aren't working at all on your Apple iPod Shuffle 2nd Gen, then press and hold your Play button to see what light sequence you're given. This is also shown by the Shuffle flashing orange when you push a button too.
If your player flashes alternating green and orange, you have no music in the shuffle. This can be because it's fresh out of the box, or because, well, something's happened and the music has vanished. Either way, time to sync with your iTunes library.
If you're seeing a flashing red sequence, you're just about out of battery and just need to plug it in so it can charge up.
Finally, Apple has some good tech notes on the new Shuffle too that you might want to check out if you're still a bit baffled by this tiny engineering wonder: Understanding status light behavior, Shuffle Second Gen, Frequently Asked Questions and iPod Shuffle Support Overview.
Ipod shuffle wont play
If iPod shuffle isn’t playing music
â iPod shuffle might not have any music on it. If you hear the message “Please use
iTunes to sync music,” connect iPod shuffle to your computer to sync music to it.
â Slide the three-way switch off and then on again.
â Make sure the earphone or headphone connector is pushed in all the way.
â Make sure the volume is adjusted properly. A volume limit might be set. See “Setting
a Volume Limit” on page 25.
â iPod shuffle might be paused. Try clicking the Center button on the earphone remote
Ipod shuffle will not sync
try clicking on summury in itunes and go through the settings then click sync in the bottom right
Ipod Shuffle Issues
use itunes to transfer music and if that doesnt work,restore your player and then transfer music...
I have bought an apple ipod shuffle in december from uk. i have downloaded the songs into ipod from computer. i am able to hear the songs in ipod from computer. i have fully charged the ipod untill the...
Green and ORANGE? orange indicates the iPod is searching for music.
UNDERSTAND this- when you play music in the iTunes app., you are hearing the music in your computer not the iPod.
1) Install the latest iTunes application.
2) Do a restore
3) sync your iPod
Can not get ipod shuffle on my computer
The orange light blinks to tell you that it connecting to the computer and is syncing (or trying to sync). It will stay orange until it is fully charged and it will then turn green. If it is blinking orange, then open it using itunes and see what it is syncing. If you have not got itunes then i recommend you download that latest version from http://www.apple.com/itunes/download/
then once you have installed it onto your computer, add your music to itunes and create a playlist that you want on your ipod. Itunes will have the drivers for you ipod. Plug your ipod into the computer and right click the image of your ipod and select sync ipod. Then choose the playlist that you want the ipod to sync with.
I hope this helps
Ipod shuffle
same has happend to me but i now have an ipod nano but i suggest you go back to using itunes
4helpful
5answers
Ipod shuffle not playing music
hai,
i am preetha.My ipod shuffle will not play any music.When i press any buttons it just blinks on the green and orange light why is this? i have put music on it and charged it.plz tell what to do.
IPOD Shuffle doesn't work at all
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
