For my 20 year old Moen 1222, I found the outer O-ring supplied with the OEM part was slightly too large to overcome the beveled brass edge near where the key fits. I reused the old, failed part's O-ring and it went in fine. If you do this method, you should check for leaks prior to restoring. I find Moen is not my preferred supplier of choice for plumbing fixtures.
SOURCE: how do I pull a moen single lever kitchen cartridge out
there is a little plastic tool that comes with a new cartridge....you use it to turn the cartridge back and forth....breaking the seal that has formed between the rubber on the outside of the cartridge and the inner wall of the valve. After doing that you should be able use a pair of channel locks to pull the cartridge out.
SOURCE: cannot remove moen sink cartridge
MOEN cartridges can be EXTREMELY difficult to remove sometimes. Be sure the horse shoe clip is out. Then you can use a crescent wrench and carefully turn the cartridge, once you get the cartridge to turn a little you can try to pull it again. They actualy make a tool to pull these. They run around $10 at your local home improvement store. The tool takes the place of the crescent and puting the handle back on to pull it. Hope this helps.
SOURCE: I am trying to remove an old cartridge from my
It just pulls off. It is just part of the trim package.
If you remove the chrome trim cover that has two screws in it first it will remove easyer but is not something you have to do.
This video is not the best but it will you see what you may be getting into.
http://www.youtube.com/watch?v=AKLBqKk-j50&feature=related
You might try a drop of penetrating oil from a car parts store. Ask for their best penetrating oil. Let it sit for about 5 minutes then try to back out hex screw.
SOURCE: i have a kitchen single lever moen faucet and the cartridge wont
- I have a single lever Moen Kitchen Faucet and it's leaking around the base on top of the sink what could it be
