20 Most Recent Moen YB2818 Eva Towel Bar Bathroom Accessory - Brushed Nickel Questions & Answers
Same problem. The key to releasing it is finding the 'latch' of the 'spring'. I wish I could upload a photo. It just snaps off the way the battery compartment opens on your TV remote. On a TV remote if you apply too much pressure then you break the 'latch' on the battery's door, as we all know it is about applying pressure it the right place of the 'spring'. Once I got the correct placement of the flat head screw driver it was easy, but it took me 30 minutes to figure that out and I broke a piece of the towel rack.
Moen YB2818 Eva... | Answered on Jun 29, 2019
u have to really push hard up on the spring and at the same time pull towards u
Moen YB2818 Eva... | Answered on Aug 24, 2015
The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
Moen YB2818 Eva... | Answered on Jun 08, 2014
check underneath for a small setscrew. back this out and it should be removable
Moen YB2818 Eva... | Answered on Jul 08, 2011
replace cartridge
Moen Home | Answered on Jul 14, 2020
https://www.google.com suggests the following link:
https://www.hunker.com/12267493/how-to-clean-a-moen-shower-head
Quoting from link above:
How to Clean a Moen Shower Head By BRENDAN O'BRIEN
Photos.com/Getty
images
Taking a shower could be hazardous to your health if you do not properly and regularly clean your shower head. According to a study at the University of Colorado at Bolder, your shower head may contain harmful bacteria. But not to worry, with some old-fashion vinegar, elbow grease and about 45 minutes, you can take a shower with peace of mind. Clean a Moen shower head while it is still attached, or remove it before cleaning.
  • Volume 0%Detached Shower Head
    Step 1
    Remove the Moen shower head. This may require pliers or vice grips. If you use tools, place a towel or rag over the shower head to protect it from scratches and dents.
    Step 2
    Remove the cover of the shower head, if there is one. The cover may twist or snap off. Do not force it if it seems stuck. This is not a requirement. You can clean the shower head with still attached.
    Step 3
    Warm the white vinegar on your stove. Do not boil the vinegar. Gauge how much vinegar you will need by the size of your Moen shower head. You need to fully submerge the shower head in the vinegar.
    Step 4
    Pour the warm white vinegar in a bowl or bucket. Place the shower head in the bowl and submerge it in the white vinegar. Let it soak for 15 to 20 minutes.
    Step 5
    Clear the holes in the shower head with a paperclip or thin wire. Clear all of the debris from the holes. Dunk and rinse the shower head back in the vinegar.
    Step 6
    Rinse the shower head and cover with hot water. Re-install the Moen shower head and cover. Test the shower to make sure you have re-installed it properly. Attached Shower Head
    Step 1
    Fill a plastic bag with warm white vinegar.
    Step 2
    Place the bag over the Moen shower head so it is complete submerged in the warm vinegar. Place a rubber band or piece of tape around the stem, securing the bag to the shower head.
    Step 3
    Remove after 15 to 20 minutes. Take an old toothbrush and scrub off the mineral deposits and debris. Rinse off the shower head thoroughly with hot water and a wet cloth. Brendan O'Brien
Moen Home | Answered on Jul 07, 2020
It is a feature to save water on a handbasin, but there is an insert or a different cartridge that you can fit for filling a bath. Contact Moen.
Moen Contact Us ' Moen
https://www.moen.ca > customer-support > contact-us
Contact Us. ... 1-800-465-6130. OR. telephone icon Email. Moen will respond to your email within 48 hours. Send an Email ... ‎Warranty Information · ‎Installation Help · ‎FAQs
Moen Home | Answered on Nov 16, 2019
remove the head remove restrictor add a gasket reconnect
Moen Home | Answered on Oct 29, 2019
Sounds like your cartridge is not properly seated and also may not be aligned properly.
Remove it and apply a thin coating of plumbers grease to the cartridge and then work it back into it's position rotating back and forth to insure it is going down all the way.
HERES A MECHANICS TRICK IF YOU HAVE STANDARD AND METRIC WRENCHES TRY BOTH AND MAYBE ONE OR THE OTHER WILL FIT BETTER...SOMETIMES A BIT O HEAT WORKS HERE ALSO... OH AND IF YOU HAVE AIR IN A CAN TURN IT UPSIDE DOWN AND HIT THE HEAD OF THE SREW TO FREEZE AND MAKE IT SHRINK TO SHOCK IT...IT SHOULD COME OUT...BARRING ALL THAT YOULL HAVE TO DRILL IT
Moen Home | Answered on Sep 14, 2019
Moen YB2818 Eva Towel Bar Bathroom Accessory - Brushed Nickel Logo
14 questions posted
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
View Most Popular
Moen Home
  • Moen Home
Most Popular Question
tighten up loose moen eva towel bar wall
  • Home
